  • 5709阅读
DVD影碟机按键旋转编码器(涡轮)程序代码 [复制链接]
楼主    小虫子 发表于: 2008-03-06 17:56:09
void polling_volume_sw(void)
    BYTE bSWValue=0;
      static BYTE iLastData=0;
    static BYTE iSWTempData = 0;
#if defined(SUPPORT_USE_SW_SCANF_CODER) || defined(SUPPORT_USE_SW_SCANF_LEVEL)
  polling_check_vfdsw();
  return;
#elif defined(VOLUME_SW_USE_IO)
      GPIO_M_SET(13,1);   //GAME DI
  GPIO_M_SET(14,1);     //GAME DO
    GPIO_E_SET(13,0);
  GPIO_E_SET(14,0);
    bSWValue =( (GPIO_I_GET(14)<<1) | (GPIO_I_GET(13) ));
  #endif
    if(bSWValue != iSWTempData)
            iSWTempData = bSWValue;
    else
          switch(bSWValue)
                case 0:
                    if(iLastData ==2)
                          iLastData ++;
                    break;
                case 1:
                    if(iLastData ==1)
                          iLastData++;
                    else if(iLastData ==3)
                          call_ir_func(IRC_VOLUME_UP);
                          iLastData = 0;
                    break;
                case 2:
                    if(iLastData ==1)
                          iLastData ++;
                    else if(iLastData == 3)
                          call_ir_func(IRC_VOLUME_DN);
                          iLastData = 0;
                    break;
                case 3:
                    iLastData =1;
                    break;
                default:
                    break;
#endif
sunplus(dvd) 环境:需源程序支持:
// generic GPIO operations
#define GPIO_I_GET(a)   ((regs0->gpio_in[a/16] >> (a%16)) & 0x01)
#define GPIO_O_SET(a,d) ((d) ? (regs0->gpio_out[a/16] |= (1<<(a%16))) \
                  : (regs0->gpio_out[a/16] &= ~(1<<(a%16))) )
#define GPIO_E_SET(a,d) ((d) ? (regs0->gpio_oe[a/16] |= (1<<(a%16))) \
                  : (regs0->gpio_oe[a/16] &= ~(1<<(a%16))) )
#define GPIO_M_SET(a,d) ((d) ? (regs0->gpio_master[a/16] |= (1<<(a%16))) \
                  : (regs0->gpio_master[a/16] &= ~(1<<(a%16))) )
#ifdef SUPPORT_XINZENYU_JOB_VOLUME //Refee 080905
BYTE volume_a_buf = 0;
BYTE volume_b_buf = 0;
void Check_Job_Volume_Key(void)
    GPIO_M_SET(13,1); //Pin62 Game_D0
    GPIO_M_SET(14,1); //Pin63 Game_D1
    GPIO_E_SET(13,1);
    GPIO_E_SET(14,1);
    GPIO_O_SET(13,1);
    GPIO_O_SET(14,1);
    volume_a_buf = volume_a_buf<<1;
    if(!GPIO_I_GET(13)) volume_a_buf++;
    volume_b_buf = volume_b_buf<<1;
    if(!GPIO_I_GET(14)) volume_b_buf++;
    volume_a_buf = volume_a_buf & 0x7;
    volume_b_buf = volume_b_buf & 0x7;
    if(volume_a_buf == 0x04)
          if(volume_b_buf >= 0x06)
          else
          volume_a_buf = 0;
          volume_b_buf = 0;
#endif
本帖最近评分记录: 共 1 条评分
