  • 3704阅读
刷机出错(带提示信息),大家帮忙看看 [复制链接]
楼主    望望天 发表于: 2010-01-13 20:05:06
BL: Initialize... Ver: bl-abs_20090105
BL: Addr[0006AF80]: ch_id[01FE0101]: crc[DB8E64B0] != ch_crc[58B9C7B5]
BL: download_flag is 0!Check application!
BL: Fail to check application!
BL: Load OTA loader to run!
BL: Jump to application...
ap_init_hardware start!
In A1108_IBase_GetVersion:
Chip.Major = 2
Chip.Minor = 1
Chip.Build = 1
Patch.Major = 4
Patch.Minor = 1
Patch.Build = 32
API.Major = 3
API.Minor = 2
API.Build = 2
end A1108_IBase_GetVersion
ap_init_hardware End!BL: Before sto_read dev=0x80212000,data=0x802a0000,sector_offset=0x10000,sector_size=0x10000!
BL: sto_read Done!
open ap_init_abs_ota OTA   INITION!
Create ui_create_desktop Finished,Press Key?
abs_ota_nim_mode_set-->nim_mod=0
abs_ota_start-->sign_len[256]-flash_offset[0x3ff80]
ABS_OTA_START-->
nim change--fre=1184000 ,syb=28800 pol=2--LNB FREQ[10750]
set to NIM_POLAR_LEFT
A1108_ITuner_GetLockStatus = 0
ota_TUNER--->LOCK!
ota_dmx_callback-->NIT
ota_nit_proc-SI_TABLE_FINISHED->ts_count[4]
NIT_FREQ=1188000
NIT_FREQ=1192000
NIT_FREQ=1196000
NIT_FREQ=1184000
ABS_OTA_NIT_DONE-->
ota_dmx_callback-->PAT
ABS_OTA_PAT_DONE-->
ota_dmx_callback-->PMT
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_NIT_FREQ-->
nim change--fre=1188000 ,syb=28800 pol=2--LNB FREQ[10750]
ota_TUNER--->LOCK!
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_NIT_FREQ-->
nim change--fre=1192000 ,syb=28800 pol=2--LNB FREQ[10750]
set to NIM_POLAR_LEFTA1108_ITuner_GetLockStatus = 0
ota_TUNER--->LOCK!
ABS_OTA_PAT_DONEota_dmx_callback-->PMT
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_NIT_FREQ-->
nim change--fre=1196000 ,syb=28800 pol=2--LNB FREQ[10750]
ota_TUNER--->LOCK!
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_NIT_FREQ-->
ota_TUNER--->LOCK!
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_PAT_DONE-->
ABS_OTA_NIT_FREQ-->
nit_done[1],nit_freq_idx[4]
ota_finish_download-->BEGIN
ABS_OTA_FINISH-->REBOOT
电视界面停在这里
然后机器就重起,重复上述提示.
