  • 3552阅读
看看这个是怎么回事,达达们。 ERROR   看着是刷完了。家里老人看的电视难啊。谢谢大家. [复制链接]
楼主    chent7988 发表于: 2010-02-02 23:51:54
Application Initialize... Ver: bt-cl-20090112
Serial FLASH on board!
Begin write data to target range...Done
Begin verify target range...Done
Finished, halt!
Ju
BL: Initialize... Ver: bl-abs_20090304
SF!
InHW: 5432803->10914324 = 63738uS
showload and W232: 11187774->32855739 = 251953uS
ChkNVRAM: 36969322->36974853 = 64uS
chkOTA: 36969322->37297860 = 3820uS
Logo: 37659807->39842722 = 25382uS
UZip: 40189152->106323999 = 769009uS
tick = 106632777
BL: Jump to app...
flash offset = 50972
APRO 0
set to NIM_POLAR_LEFT
channel_change: tunerPllOffset=0
Current Software Date:2010.01.06,Ram Size=0x800000
No match: 261-1-0
BL: Before sto_read dev=0x8012e8b0,data=0x8023e028,sector_offset=0x10000,sector_size=0x10000!
BL: sto_read Done!
No match: 289-0-1
tick 2
system time ==1199145600
Enter ap_channel_play_current_channel,time=2570
vol compensate = 0
[color=red]epg error, not find service 1 1 3ee when check finish
epg error, not find service 1 1 3ee when check finish[/color]
Enter wm_common_main,time=232008238 Press Key?
pe_warn: pe already in PE_STATE_STOP state!
VDEC_FIRST_PIC
红色的 ERROR 错在哪了啊 还是BIN不对应么?
刷了好几个BIN 都是显示 P800 或者 P00 机顶盒 然后屏幕只闪过村村通画面 其他没有
附上原机BIN 连续奋战数小时 不得其解 菜鸟啊菜鸟 杯具啊杯具
高手帮忙看看 或者给他、改改
机子是 卓异 5518A
HTV903 + AVL1108EGa + 5812 单晶振
PCB板 PCB900+5810/A   接口4针 用RS232转TTL小板连接
