  • 7474阅读
dvb 大亚 DC 4600 有线机顶盒,请备份 刷机软件! [复制链接]
楼主    whscl2008 发表于: 2011-02-18 11:26:48
此机顶盒连接rs232口,导出的数据如下,希望能有帮助,
Enabling serial checkpoint output.
Setting up ASB mode.
Removing ROM shadow from address 0.
Initializing RAM controller.
Initializing 'C' variables.
Enabling I cache.
Initializing stack pointers for each CPU mode.
Switching to 'C' code.
Initializing the GPIO pins.
Serial Port re-initialized. Now using CheckpointC.
Initializing Flash.
Calculating MemClkPeriod.
Going to boot from 0x20020000.
Initializing MMU and caches.
Decompressing LZO image.
Decompress sucessfully!
Branching to loaded code image's entry   point.
Disabling interrupts via the interrupt controller.
Initializing ROM controller registers.
Initializing ISA controller registers.
Setting the RTC clock.
Initializing PCI.
KAL early initialization.
Initializing exception vectors.
Initializing OS variables.
Starting OS initialization.
Trace output port opened
KAL initialised. Return code 1
Loader is running!
DRV version hwLibBoot_daya_M0107V001B_1
hello baustem!
loader initial
LOADER VERSION: DAYACNXT_V1.0.1
Loader Starting [clock: 296]
*****rom info************************************
OUI:    90-60-20
HW: model:107    version:0-1b
MAC: 8-20-0
UID: 28 10 38 3c 65 6a 5b 3d 0 0 0 0 0 0 0 0
*****************rom ok***************
*******picture verify ok*********
*****************data1 ok***************
biAppUpdateCtrlInfoParse: check section tag fail (ff)
search mode :2
*************RTBooter started.
Setting up GPIOs.
Enabling I cache.
Initializing Flash.
RTBooting.
Decompressing gz image.
Initializing PCI.
00.00.000: KAL process wrapper called for task at 0x004a810d. Index 58
00.00.000: KAL process wrapper called for task at 0x00479a21. Index 57
00.00.000: Clean Up Task Woken Up.
00.00.001: KAL process wrapper called for task at 0x00472e3d. Index 56
00.00.001: KAL process wrapper called for task at 0x004a4485. Index 55
GET QRY OK.
test get esn : 28 10 38 3C 65 6A 5B 3D
00.00.021: 0x00170001: Warning from Unknown (file D:\BRAZOS_AL_BSP\src_fouxu\BSP\CNXT_BRAZOS\NV\NVSTOR.c, line 116)
00.00.021: 0x00170008: Warning from Unknown (file D:\BRAZOS_AL_BSP\src_fouxu\BSP\CNXT_BRAZOS\NV\NVSTOR.c, line 389)
00.00.022: 0x00170001: Warning from Unknown (file D:\BRAZOS_AL_BSP\src_fouxu\BSP\CNXT_BRAZOS\NV\NVSTOR.c, line 116)
00.00.022: 0x00170008: Warning from Unknown (file D:\BRAZOS_AL_BSP\src_fouxu\BSP\CNXT_BRAZOS\NV\NVSTOR.c, line 389)
00.00.003: KAL process wrapper called for task at 0x004952a5. Index 53
00.00.008: KAL process wrapper called for task at 0x00473821. Index 51
00.00.017: KAL process wrapper called for task at 0x0047fcf1. Index 50
00.00.020: KAL process wrapper called for task at 0x00480e89. Index 49
00.00.022: Can't write config info to flash!
00.00.022: Can't write BSP config info to flash!
00.00.022: KAL process wrapper called for task at 0x004b6ced. Index 48
00.00.023: InitMPEGVideo: WaitOnCtrl
00.00.024: InitMPEGVideo: Sending InitIPB
00.00.024: KAL process wrapper called for task at 0x00494dbd. Index 54
00.00.024: KAL process wrapper called for task at 0x00484a79. Index 52
00.00.155: VIDEO: Patching duplicate adjacent temporal references in still
00.00.235: VIDEO: Patching duplicate adjacent temporal references in still
00.00.316: VIDEO: Patching duplicate adjacent temporal references in still
00.00.317: KAL process wrapper called for task at 0x004535ed. Index 47
00.00.557: KAL process wrapper called for task at 0x004770a5. Index 44
00.00.556: KAL process wrapper called for task at 0x00479f51. Index 46
00.00.557: KAL process wrapper called for task at 0x00476869. Index 45
00.00.895: KAL process wrapper called for task at 0x0044f049. Index 43
00.00.895: KAL process wrapper called for task at 0x004995e5. Index 42
00.00.896: KAL process wrapper called for task at 0x00499529. Index 41
[cacore]: [DG_CA_API_FilterInit]
[cacore]: [BaustemChanInit]
[cacore]: [BaustemDescramInit]
vivian test ConfigCAFlashRead +++
R Addr=0x2003e000,Len=0x2000
>Baustem Flash Operation Zone start!
sector_num=10
cur_sector_size=0x10000 flash_base_addr=0x20030000 read_size=0x10000
test 1111++++ data_size =0x2000 Addr=0x20040000 Buff=0xfe0458 read_len=0x2000
Baustem Flash Operation Zone Over!
[cacore]: boot strap addr = 0x20000000, size = 65536
R Addr=0x20000000,Len=0x8000
sector_num=0
cur_sector_size=0x2000 flash_base_addr=0x20000000 read_size=0x2000
test 1111++++ data_size =0x2000 Addr=0x20002000 Buff=0xfd8448 read_len=0x2000
cur_sector_size=0x2000 flash_base_addr=0x20002000 read_size=0x2000
test 1111++++ data_size =0x4000 Addr=0x20004000 Buff=0xfda448 read_len=0x2000
cur_sector_size=0x2000 flash_base_addr=0x20004000 read_size=0x2000
test 1111++++ data_size =0x6000 Addr=0x20006000 Buff=0xfdc448 read_len=0x2000
cur_sector_size=0x2000 flash_base_addr=0x20006000 read_size=0x2000
test 1111++++ data_size =0x8000 Addr=0x20008000 Buff=0xfde448 read_len=0x2000
R Addr=0x20008000,Len=0x8000
sector_num=4
cur_sector_size=0x2000 flash_base_addr=0x20008000 read_size=0x2000
test 1111++++ data_size =0x2000 Addr=0x2000a000 Buff=0xfd8448 read_len=0x2000
cur_sector_size=0x2000 flash_base_addr=0x2000a000 read_size=0x2000
test 1111++++ data_size =0x4000 Addr=0x2000c000 Buff=0xfda448 read_len=0x2000
cur_sector_size=0x2000 flash_base_addr=0x2000c000 read_size=0x2000
test 1111++++ data_size =0x6000 Addr=0x2000e000 Buff=0xfdc448 read_len=0x2000
cur_sector_size=0x2000 flash_base_addr=0x2000e000 read_size=0x2000
test 1111++++ data_size =0x8000 Addr=0x20010000 Buff=0xfde448 read_len=0x2000
[cacore]: loader image addr = 0x20010000, size = 188416
R Addr=0x20010000,Len=0x8000
sector_num=8
cur_sector_size=0x10000 flash_base_addr=0x20010000 read_size=0x10000
test 1111++++ data_size =0x8000 Addr=0x20018000 Buff=0xfde448 read_len=0x8000
R Addr=0x20018000,Len=0x8000
sector_num=8
test 1111++++ data_size =0x8000 Addr=0x20020000 Buff=0xfde448 read_len=0x8000
R Addr=0x20020000,Len=0x8000
sector_num=9
cur_sector_size=0x10000 flash_base_addr=0x20020000 read_size=0x10000
test 1111++++ data_size =0x8000 Addr=0x20028000 Buff=0xfde448 read_len=0x8000
R Addr=0x20028000,Len=0x8000
sector_num=9
test 1111++++ data_size =0x8000 Addr=0x20030000 Buff=0xfde448 read_len=0x8000
R Addr=0x20030000,Len=0x8000
sector_num=10
test 1111++++ data_size =0x8000 Addr=0x20038000 Buff=0xfde448 read_len=0x8000
R Addr=0x20038000,Len=0x6000
sector_num=10
test 1111++++ data_size =0x6000 Addr=0x2003e000 Buff=0xfdc448 read_len=0x6000
[cacore]: firmware addr = 0x2003e000, size = 8192
R Addr=0x2003e000,Len=0x1f80
sector_num=10
test 1111++++ data_size =0x1f80 Addr=0x2003ff80 Buff=0xfd83c8 read_len=0x1f80
[cacore]: sig addr = 0x2003ff80, size = 128d
R Addr=0x2003ff80,Len=0x80
sector_num=10
test 1111++++ data_size =0x80 Addr=0x20040000 Buff=0x8b7814 read_len=0x80
[cacore]: cert addr = 0x2003e700, size = 1536
R Addr=0x2003e700,Len=0x600
sector_num=10
test 1111++++ data_size =0x600 Addr=0x2003ed00 Buff=0x8b5d84 read_len=0x600
R Addr=0x2003ed00,Len=0x600
sector_num=10
test 1111++++ data_size =0x600 Addr=0x2003f300 Buff=0x8b6588 read_len=0x600
R Addr=0x2003f300,Len=0x600
sector_num=10
test 1111++++ data_size =0x600 Addr=0x2003f900 Buff=0x8b6d8c read_len=0x600
R Addr=0x2003f900,Len=0x600
sector_num=10
test 1111++++ data_size =0x600 Addr=0x2003ff00 Buff=0x8b7590 read_len=0x600
R Addr=0x2003e680,Len=0x6
sector_num=10
test 1111++++ data_size =0x6 Addr=0x2003e686 Buff=0x8cf1f6 read_len=0x6
R Addr=0x2003e640,Len=0x20
sector_num=10
test 1111++++ data_size =0x20 Addr=0x2003e660 Buff=0x8cf210 read_len=0x20
R Addr=0x2003e600,Len=0x20
sector_num=10
test 1111++++ data_size =0x20 Addr=0x2003e620 Buff=0x8cf210 read_len=0x20
R Addr=0x2003e660,Len=0x20
sector_num=10
test 1111++++ data_size =0x20 Addr=0x2003e680 Buff=0x8cf210 read_len=0x20
R Addr=0x4e400,Len=0x100
  cannot find address error
R Addr=0x20090000,Len=0x2000
sector_num=16
cur_sector_size=0x10000 flash_base_addr=0x20090000 read_size=0x10000
test 1111++++ data_size =0x2000 Addr=0x20092000 Buff=0xfe0458 read_len=0x2000
sector_num=10
test 1111++++ data_size =0x20 Addr=0x2003e680 Buff=0x8b5784 read_len=0x20
[cacore]: vivian test ConfigCAFlashRead +++
R Addr=0x20098000,Len=0x10
sector_num=16
test 1111++++ data_size =0x10 Addr=0x20098010 Buff=0x8b5764 read_len=0x10
[cacore]: start verify cert1
[cacore]: cert1 ok, start verify cert2
[cacore]: cert2 ok, start verify cert3
R Addr=0x200b1000,Len=0x800
sector_num=18
cur_sector_size=0x10000 flash_base_addr=0x200b0000 read_size=0x10000
test 1111++++ data_size =0x800 Addr=0x200b1800 Buff=0x8b1420 read_len=0x800
[cacore]: cert3 ok
[cacore]: start verify cert4-1
R Addr=0x200b0000,Len=0x800
sector_num=18
test 1111++++ data_size =0x800 Addr=0x200b0800 Buff=0x8b1420 read_len=0x800
[cacore]: cert4 - 1 ok
[cacore]: cert3 ok, start verify cert4-2
R Addr=0x200b0800,Len=0x800
sector_num=18
test 1111++++ data_size =0x800 Addr=0x200b1000 Buff=0x8b1420 read_len=0x800
[cacore]: verify cert finished successfully
[cacore]: CACoreIcInit: card agent init failed
[cacore]: [cacore] configca init ok. Nov 17 2009 V1.0
STBConfigCAInit =0
00.01.097: ##cnxt_dmx_channel_set_pid dmxid:0x0 chid:0x19 pid:0x14
00.01.113: KAL process wrapper called for task at 0x004b383d. Index 40
00.01.114: mw_si_monitor_init return value 1
00.01.169: DG_AL_NV_FAKE_EEPROM_init ok!
00.01.170: mw_si_monitor_open_sdt
00.01.170: si_monitor_sdt_open
00.01.171: ##cnxt_dmx_channel_set_pid dmxid:0x0 chid:0x1a pid:0x11
00.01.171: mw_si_monitor_open_pat
00.01.171: si_monitor_pat_open
00.01.172: ##cnxt_dmx_channel_set_pid dmxid:0x0 chid:0x1b pid:0x0
00.01.238: ##cnxt_dmx_channel_set_pid dmxid:0x0 chid:0x1c pid:0x12
00.01.239: [DG_CA_API_Register_MsgUI]
00.01.239: [DG_CA_API_Register_Mail]
00.01.239: [DG_CA_API_Register_Feed]
00.01.239: [DG_CA_API_Register_Detitle]
00.01.239: [DG_CA_API_Register_CAOSD]
00.01.239: [DG_CA_API_Register_IPPVUI]
00.01.239: [DG_CA_API_Register_Finger]
00.01.239: [DG_CA_API_EnableRegion]
00.01.240: mw_si_monitor_open_cat
00.01.240: si_monitor_cat_open
00.01.240: ##cnxt_dmx_channel_set_pid dmxid:0x0 chid:0x1d pid:0x1
00.01.244: DG_SC_Init(0)=000.01.245: [SC_Init]: TRUE
00.01.245: [DG_CA_API_UI_Init]
00.01.245: DG_SC_Reset(SC0 0)(0)=9
00.01.245: [DG_CA_API_Insertpro]Error: DG_AL_smc_Reset failed
00.01.245: [DG_CA_API_Init]
00.01.245: [SetPrintLevel]
00.01.521: ********************total md5 start********************length=16
0000: 7f 33 63 f6 9f a6 a6 a9 ec 9b 7f a5 83 f6 d8 bd
00.01.522: ********************total md5 end********************
00.01.595: KAL process wrapper called for task at 0x00423869. Index 39
00.01.596: KAL process wrapper called for task at 0x0049f0c9. Index 37
[notifyBaustemPrivateDataTask]
R Addr=0x200bbd00,Len=0x4000
sector_num=18
test 1111++++ data_size =0x4000 Addr=0x200bfd00 Buff=0x101e840 read_len=0x4000
[cacore]: acs_get_token_list info:head invalid
[cacore]: [tokenListDescriptorMngInit] read tokenRecord error.
R Addr=0x200b2800,Len=0x1000
sector_num=18
test 1111++++ data_size =0x1000 Addr=0x200b3800 Buff=0xff1478 read_len=0x1000
[cacore]: acs_get_pro_package info:head invalid
[cacore]: proPackageInit: acs_get_pro_package failed
R Addr=0x200b3800,Len=0x1000
sector_num=18
test 1111++++ data_size =0x1000 Addr=0x200b4800 Buff=0xff1478 read_len=0x1000
[cacore]: emm_parse_card_service: uni card service ver = 4, com = 0
[cacore]: process info: this service should be processed
R Addr=0x200b7800,Len=0x200
sector_num=18
test 1111++++ data_size =0x200 Addr=0x200b7a00 Buff=0xff0678 read_len=0x200
R Addr=0x200b4800,Len=0x1000
sector_num=18
test 1111++++ data_size =0x1000 Addr=0x200b5800 Buff=0xff1478 read_len=0x1000
[cacore]: acs_get_next_card_service_emm info:head invalid
R Addr=0x200b5800,Len=0x1000
sector_num=18
test 1111++++ data_size =0x1000 Addr=0x200b6800 Buff=0xff1478 read_len=0x1000
[cacore]: emm_parse_authorize_service: uni auth ver = 4, com = 1
R Addr=0x200b6800,Len=0x1000
sector_num=18
test 1111++++ data_size =0x1000 Addr=0x200b7800 Buff=0xff1478 read_len=0x1000
[cacore]: acs_get_next_auth_service info:head invalid
R Addr=0x200bbc00,Len=0x100
sector_num=18
test 1111++++ data_size =0x100 Addr=0x200bbd00 Buff=0x8f3608 read_len=0x100
R Addr=0x200b7c00,Len=0x3e00
sector_num=18
test 1111++++ data_size =0x3e00 Addr=0x200bba00 Buff=0x101e640 read_len=0x3e00
R Addr=0x200bba00,Len=0x200
sector_num=18
test 1111++++ data_size =0x200 Addr=0x200bbc00 Buff=0x101e850 read_len=0x200
00.02.478: KAL process wrapper called for task at 0x004541f5. Index 35
00.02.478: [OS_DRV_TaskMgr]
00.04.736: [ConfigCASemCreate]
00.04.746: [ConfigCASemCreate]
00.04.761: >[ConfigCAEmailNotify]
00.04.761: CA_EMAIL_NOTIFY_NONE00.04.761: KAL process wrapper called for task at 0x004541f5. Index 34
00.04.762: [OS_DRV_TaskMgr]
00.04.762: KAL process wrapper called for task at 0x004541f5. Index 33
00.04.762: KAL process wrapper called for task at 0x004541f5. Index 32
00.05.493: [VOD SI] DG_MW_nit_verion_check_start DG_AL_nim_tune error锁定失败
00.05.493: DG_AL_dmx_filter_open
00.05.493: ##cnxt_dmx_channel_set_pid dmxid:0x0 chid:0x1e pid:0x10
00.05.494: DG_sem_get wait
00.14.100: Demod timeout, retry.
00.15.575: DG_sem_get wait timeout
00.15.575: DG_MW_nit_verion_check_start FREQ=443 symb=6875 qam=64
00.15.575: DG_AL_nim_tune
00.15.575: [VOD SI] DG_MW_nit_verion_check_start 1 DG_AL_nim_tune error
[cacore]: romVerify:verify passed!
00.18.593: [VOD SI] DG_MW_nit_verion_check_start DG_AL_nim_tune error锁定失败
00.18.593: DG_AL_dmx_filter_open
00.18.593: ##cnxt_dmx_channel_set_pid dmxid:0x0 chid:0x1e pid:0x10
00.18.594: DG_sem_get wait
00.24.582: Demod timeout, retry.
00.28.633: DG_sem_get wait timeout
00.28.633: DG_MW_nit_verion_check_start FREQ=443 symb=6875 qam=64
00.28.633: DG_AL_nim_tune
00.28.633: [VOD SI] DG_MW_nit_verion_check_start 1 DG_AL_nim_tune error
00.31.647: [VOD SI] DG_MW_nit_verion_check_start DG_AL_nim_tune error锁定失败
00.31.647: DG_AL_dmx_filter_open
00.31.647: ##cnxt_dmx_channel_set_pid dmxid:0x0 chid:0x1e pid:0x10
00.31.648: DG_sem_get wait
R Addr=0x200b1800,Len=0x1000
sector_num=18
test 1111++++ data_size =0x1000 Addr=0x200b2800 Buff=0xff1478 read_len=0x1000
00.33.078: [ConfigCAShowCASMsg]
00.33.078: [ConfigCAShowCASMsg]   default msg_type=27
00.35.058: Demod timeout, retry.
00.35.097: [ConfigCAShowCASMsg]
00.35.097: [ConfigCAShowCASMsg]   default msg_type=27
[cacore]: [DG_CA_API_onChangeChannel]
00.41.697: DG_sem_get wait timeout
00.41.697: DG_MW_chm_channel_select_power_on_program ++
00.41.697: mw_si_monitor_stop_pmt
00.41.698: mw_si_monitor_stop_cat
00.41.698: mw_si_monitor_open_cat
00.41.698: si_monitor_cat_open
00.41.698: ##cnxt_dmx_channel_set_pid dmxid:0x0 chid:0x1d pid:0x1
00.41.699: DG_MW_AV_msg_send_pid
00.41.699: 凤凰电影11111- : service_type 1,ca_system_id 19187, pmt_pid 5001
00.41.699: mw_si_monitor_reset
00.41.699: Different Tp ,DG_MW_nit_verion_check_Main_Tp_start
00.41.700: ##cnxt_dmx_channel_set_pid dmxid:0x0 chid:0x1e pid:0x10
00.41.700: DG_MW_AV_msg_send_pid
00.41.700: mw_si_monitor_open_pmt
00.41.700: si_monitor_pmt_open
00.41.701: ##cnxt_dmx_channel_set_pid dmxid:0x0 chid:0x1f pid:0x1389
00.41.761: ##cnxt_dmx_channel_set_pid dmxid:0x0 chid:0x2 pid:0x1ffe
00.41.761: ##cnxt_dmx_channel_set_pid dmxid:0x0 chid:0x1 pid:0x1fff
00.41.762: Clean Up Task Woken Up.
00.42.001: av stop
volume independent ++
volume self=16 offset=10 ++
00.42.081: track=0 volume=26
00.42.081: av_msg.parm1=0x1000 =0x31 =0x1000
00.42.123: PID=0x1fffIDLE, Demux disable_reset called
00.42.123: ##cnxt_dmx_channel_set_pid dmxid:0x0 chid:0x2 pid:0x1ffe
00.42.123: ##cnxt_dmx_channel_set_pid dmxid:0x0 chid:0x1 pid:0x1fff
00.42.223: ##cnxt_dmx_channel_set_pid dmxid:0x0 chid:0x2 pid:0x31
00.42.223: ##cnxt_dmx_channel_set_pid dmxid:0x0 chid:0x1 pid:0x1000
00.42.463: DG_CHM__write_channel
00.45.180: [ConfigCAShowCASMsg]
00.45.180: [ConfigCAShowCASMsg]   default msg_type=27
00.50.709: VIDEO: Patching duplicate adjacent temporal references in still
[cacore]: >[DG_CA_BaustemNitCheck]
00.53.516: Demod timeout, retry.
00.55.253: [ConfigCAShowCASMsg]
00.55.253: [ConfigCAShowCASMsg]   default msg_type=27
01.02.392: ++++[write_flash] addr:0x20500000 size:0x0
01.02.392: ++++[write_flash] addr:0x20500000 size:0x10000
01.02.660: fake eep freshed!
01.04.154: Demod timeout, retry.
01.05.335: [ConfigCAShowCASMsg]
01.05.335: [ConfigCAShowCASMsg]   default msg_type=27
01.14.775: Demod timeout, retry.
01.15.407: [ConfigCAShowCASMsg]
01.15.407: [ConfigCAShowCASMsg]   default msg_type=27
01.25.407: Demod timeout, retry.
01.25.497: [ConfigCAShowCASMsg]
01.25.498: [ConfigCAShowCASMsg]   default msg_type=27
01.35.564: [ConfigCAShowCASMsg]
01.35.564: [ConfigCAShowCASMsg]   default msg_type=27
01.36.013: Demod timeout, retry.
01.45.634: [ConfigCAShowCASMsg]
01.45.634: [ConfigCAShowCASMsg]   default msg_type=27
01.46.654: Demod timeout, retry.
01.55.726: [ConfigCAShowCASMsg]
01.55.726: [ConfigCAShowCASMsg]   default msg_type=27
01.57.303: Demod timeout, retry.
[cacore]: account hw model = 0x107, ver = 0x1b, cas ver = 1.0
12.01.622: [DG_CA_BAUSTEM_VerInfo]
12.01.622: [DG_CA_Get_BaustemAccountInfo]
12.01.622: user_id=0000121861 card_sn=20EA573EF121C5C6
12.01.622: operator=TaianCable region_id=8004
12.01.622: account_type=1 account_ver=4
12.01.622: card_start_time=1295969147 card_end_time=1844121600
