  • 5122阅读
请各位高手帮忙提供MC44BS373CA全频道,AT89C2051 I2C总线汇编控制驱动程序 [复制链接]
楼主    peiqing3412 发表于: 2011-02-24 20:48:56
请各位高手帮忙提供MC44BS373CA全频道,AT89C2051 I2C总线汇编控制驱动程序,或者是BIN,HEX档也行,本人将不盛感激,谢谢!以下是单频道的(请各位高手帮忙修改为多频道的)
AT89C2051 MC44BS373CA
Q0000:         AJMP Q0040
            XCH   A,R2
            MOV   10H,R0
            JB   2EH.4,Q0039
            INC   @R1
            INC   @R0
            NOP
Q0039:         NOP
Q0040:         MOV   R4,#0F0H
            DJNZ R4,$
            MOV   DPTR,#0030H
            MOV   A,#00H
            MOVC A,@A+DPTR
            MOV   60H,A
            MOV   A,#01H
            MOVC A,@A+DPTR
            MOV   61H,A
            MOV   A,#02H
            MOVC A,@A+DPTR
            MOV   62H,A
            MOV   A,#03H
            MOVC A,@A+DPTR
            MOV   63H,A
            MOV   A,#04H
            MOVC A,@A+DPTR
            MOV   64H,A
            MOV   A,#05H
            MOVC A,@A+DPTR
            MOV   65H,A
            MOV   A,#06H
            MOVC A,@A+DPTR
            MOV   66H,A
            MOV   A,#07H
            MOVC A,@A+DPTR
            MOV   67H,A
Q006F:         MOV   A,60H
            MOV   R1,#61H
            MOV   R2,#04H
            ACALL Q0086
            CJNE A,#01H,Q007C
            INC   65H
Q007C:         ACALL Q00EF
            DJNZ 65H,Q006F
            ORL   PCON,#03H
Q0084:         AJMP Q0084
Q0086:         ACALL Q009D
            ACALL Q00C3
            JC   Q0098
Q008C:         MOV   A,@R1
            ACALL Q00C3
            JC   Q0098
            INC   R1
            DJNZ R2,Q008C
            MOV   A,#00H
            AJMP Q009A
Q0098:         MOV   A,#01H
Q009A:         ACALL Q00B2
            RET
Q009D:         PUSH ACC
            ACALL Q0102
            ACALL Q00EA
            ACALL Q00F8
            ACALL Q00EA
            ACALL Q0116
            ACALL Q00EA
            ACALL Q010C
            ACALL Q00EA
            POP   ACC
            RET
Q00B2:         PUSH ACC
            ACALL Q0116
            ACALL Q00EA
            ACALL Q00F8
            ACALL Q00EA
            ACALL Q0102
            ACALL Q00EA
            POP   ACC
            RET
Q00C3:         MOV   R0,#08H
            MOV   68H,A
Q00C7:         ACALL Q012A
            ACALL Q00EA
            ACALL Q00F8
            ACALL Q00EA
            ACALL Q010C
            ACALL Q00EA
            DJNZ R0,Q00C7
            ACALL Q0102
            ACALL Q00EA
            ACALL Q00F8
            ACALL Q00EA
            ACALL Q0120
            MOV   69H,PSW
            ACALL Q010C
            ACALL Q00EA
            MOV   PSW,69H
            RET
Q00EA:         NOP
            RET
Q00EF:         MOV   R6,#14H
Q00F1:         MOV   R7,#0A5H
            DJNZ R7,$
            DJNZ R6,Q00F1
            RET
Q00F8:         MOV   DPTR,#013FH
            MOV   B,#03H
            MOV   A,66H
            MUL   AB
            JMP   @A+DPTR
Q0102:         MOV   DPTR,#013FH
            MOV   B,#03H
            MOV   A,67H
            MUL   AB
            JMP   @A+DPTR
Q010C:         MOV   DPTR,#016FH
            MOV   B,#03H
            MOV   A,66H
            MUL   AB
            JMP   @A+DPTR
Q0116:         MOV   DPTR,#016FH
            MOV   B,#03H
            MOV   A,67H
            MUL   AB
            JMP   @A+DPTR
Q0120:         MOV   DPTR,#01CFH
            MOV   B,#03H
            MOV   A,67H
            MUL   AB
            JMP   @A+DPTR
Q012A:         MOV   A,68H
            RLC   A
            MOV   68H,A
            MOV   69H,PSW
            MOV   DPTR,#019FH
            MOV   B,#03H
            MOV   A,67H
            MUL   AB
            MOV   PSW,69H
            JMP   @A+DPTR
            SETB P1.0
            RET
Q0142:       DB 0D2H, 91H, 22H,0D2H, 92H, 22H,0D2H, 93H
Q014A:       DB 22H,0D2H, 94H, 22H,0D2H, 95H, 22H,0D2H
Q0152:       DB 96H, 22H,0D2H, 97H, 22H,0D2H,0B0H, 22H
Q015A:       DB 0D2H,0B1H, 22H,0D2H,0B2H, 22H,0D2H,0B3H
Q0162:       DB 22H,0D2H,0B4H, 22H,0D2H,0B5H, 22H,0D2H
Q016A:       DB 0B6H, 22H,0D2H,0B7H, 22H,0C2H, 90H, 22H
Q0172:       DB 0C2H, 91H, 22H,0C2H, 92H, 22H,0C2H, 93H
Q017A:       DB 22H,0C2H, 94H, 22H,0C2H, 95H, 22H,0C2H
Q0182:       DB 96H, 22H,0C2H, 97H, 22H,0C2H,0B0H, 22H
Q018A:       DB 0C2H,0B1H, 22H,0C2H,0B2H, 22H,0C2H,0B3H
Q0192:       DB 22H,0C2H,0B4H, 22H,0C2H,0B5H, 22H,0C2H
Q019A:       DB 0B6H, 22H,0C2H,0B7H, 22H, 92H, 90H, 22H
Q01A2:       DB 92H, 91H, 22H, 92H, 92H, 22H, 92H, 93H
Q01AA:       DB 22H, 92H, 94H, 22H, 92H, 95H, 22H, 92H
Q01B2:       DB 96H, 22H, 92H, 97H, 22H, 92H,0B0H, 22H
Q01BA:       DB 92H,0B1H, 22H, 92H,0B2H, 22H, 92H,0B3H
Q01C2:       DB 22H, 92H,0B4H, 22H, 92H,0B5H, 22H, 92H
Q01CA:       DB 0B6H, 22H, 92H,0B7H, 22H,0A2H, 90H, 22H
Q01D2:       DB 0A2H, 91H, 22H,0A2H, 92H, 22H,0A2H, 93H
Q01DA:       DB 22H,0A2H, 94H, 22H,0A2H, 95H, 22H,0A2H
Q01E2:       DB 96H, 22H,0A2H, 97H, 22H,0A2H,0B0H, 22H
Q01EA:       DB 0A2H,0B1H, 22H,0A2H,0B2H, 22H,0A2H,0B3H
Q01F2:       DB 22H,0A2H,0B4H, 22H,0A2H,0B5H, 22H,0A2H
Q01FA:       DB 0B6H, 22H,0A2H,0B7H, 22H
各位大哥哥们与高手,难道论坛里没有好心人能够回复吗?
另我有同一颗飞思卡尔的同类芯片AS44CC373CA,SDA,SDL不能通讯,请各位大哥哥们指导一下,是哪里的问题,谢谢喽!本人好着急.........
#include "reg52.h"
#define   FALSE 0
#define   TRUE 1
//#define   SET   1
//#define   CLR   0
#define   C1_H   0x90
#define   C0_L   0x08
sbit SDA=P3^0;
sbit SCL=P3^1;
void delay(unsigned char m)
{ char i;
  for(i=m;i>=0;i--)
void start_i2c(void)
SDA=1;
SCL=1;
delay(2);
SDA=0;
delay(2);
SCL=0;
void stop_i2c(void)
  SCL=0;
  SDA=0;
  delay(2);
  SCL=1;
  delay(2);
  SDA=1;
  //delay(2);
  //SCL=0;
void send_1(void)
SCL=0;
SDA=1;
delay(2);
SCL=1;
delay(2);
void send_0(void)
SCL=0;
SDA=0;
delay(2);
SCL=1;
delay(2);
bit check_ack(void)
bit q;
SCL=0;
SDA=1;
delay(1);
q=SDA;
delay(1);
SCL=1;
delay(2);
if(q==1)
  return FALSE;
else
  return TRUE;
void write_i2c_byte(unsigned char temp)
unsigned char i;
for(i=0;i<8;i++)
  if((temp<<i)&0x80)
  send_1();
  else
  send_0();
SCL=0;
bit signal_send(unsigned int tmp)
unsigned char fm_h,fm_l;
bit ack=1;
fm_h=(unsigned char)(tmp>>6);
fm_l=(unsigned char)(tmp<<2)&0xff;
start_i2c();
write_i2c_byte(0xce);
ack=check_ack();
if(ack==0)
  return 0;
write_i2c_byte(fm_h);
ack=check_ack();
if(ack==0)
  return 0;
write_i2c_byte(fm_l);
ack=check_ack();
if(ack==0)
  return 0;
write_i2c_byte(C1_H);
ack=check_ack();
write_i2c_byte(C0_L);
ack=check_ack();
if(ack==0)
  return 0;
stop_i2c();
return 1;
void main(void)
unsigned char acknow=1;
//unsigned int temp=0x0b9;
while(1)
  //key_fun();
while(!acknow)
    acknow=signal_send(freq_data);
