  • 8021阅读
“大多数”哥们来看看。HTV903方案小有成效,但也失败了。 [复制链接]
hankw
楼主    hankw 发表于: 2010-01-08 12:06:17
HTV903的方案。
zip压缩包的是读出来的bin文件。
rar压缩包的是我修改后烧回去的bin文件。
我把原来读出来的bin文件刷进去,很成功,自动开机显示CCTV1,还是原来的12个台。
按照“大多数”哥们的方法替换了一个台,刷机提示有问题,手动关电源在开机后自动搜索到还是原来的12个台。
看来“大多数”哥们的方法不行呀。一个问题是刷机提示有问题,另一个问题是开机自动搜台。
刷机成功的提示是:
Application Initialize
Serial FLASH on board!
Begin write data to target rangeDone
Begin verify target rangeDone
Finished, reboot!
BL: Initialize Ver: bl-abs_20090304
tick = 125253118
BL: Jump to app
Enter 0x45= 0, finish,time=48
flash offset = 46420
Enter dev_open 0x45= 1,time=152
APRO 0
Enter nim_avl1108_attach, time=153
Enter nim_avl1108_open,time=154
Enter nim_avl1108_open finish,time=549
set to NIM_POLAR_LEFT
frequency=0x1090,   Temp=0x2880
A1108_ITuner_GetLockStatus = 0
Enter nim_channel_change finish,time=577
Current Software Date:2009.09.22,Ram Size=0x800000
Enter vsffs_initialize,time=578
No match: 261-1-0
BL: Before sto_read dev=0x8014a000,data=0x802d9000,sector_offset=0x10000,sector_size=0x10000!
BL: sto_read Done!
vdec_1st_pic<842>
into VDEC_FIRST_PIC = 936
tick 1
system time ==1199145600
Enter ap_channel_play_current_channel,time=1019
frequency=0x1130,   Temp=0x2880
vol compensate = 0
PCR<608ee5d3>STC<acaf>DIFF<608e3924>WAIT
PCR<608ee765>STC<ae3f>DIFF<608e3926>RST
APPE608eff3b, 608f0416, fffffb25
epg error, not find service 1 1 3e9 when check finish
vdec_1st_pic<1472>
into VDEC_FIRST_PIC = 1474
[Pf]:<stc:608f2e2b-pts:608f80c3=00005298>
[Pf]:<stc:608f3534-pts:608f80c3=00004b8f>
[Pf]:<stc:608f3c3b-pts:608f80c3=00004488>
[Pf]:<stc:608f4344-pts:608f80c3=00003d7f>
[Pf]:<stc:608f4a4b-pts:608f80c3=00003678>
[Pf]:<stc:608f5154-pts:608f80c3=00002f6f>
[Pf]:<stc:608f585c-pts:608f80c3=00002867>
0110-00-08 03:49:40--sys_tdt_sectime=1262922580
[Pf]:<stc:608f5f64-pts:608f80c3=0000215f>
[Pf]:<stc:608f666b-pts:608f80c3=00001a58>
[Pf]:<stc:608f6d73-pts:608f80c3=00001350>
Enter wm_common_main,time=259475981 Press Key?
刷机不成功的提示是:
Finished, reboot!
tick = 125253475
BL: Jump to app
Enter 0x45= 0, finish,time=50
flash offset = 0
flash offset = 16
flash offset = 32
flash offset = 56
flash offset = 80
flash offset = 104
flash offset = 140
flash offset = 788
flash offset = 820
flash offset = 844
Enter dev_open 0x45= 1,time=701
APRO 0
Enter nim_avl1108_attach, time=702
Enter nim_avl1108_open,time=702
Enter nim_avl1108_open finish,time=1098
Enter nim_channel_change finish,time=1126
Enter vsffs_initialize,time=1127
No match: 261-1-0
BL: Before sto_read dev=0x8014a000,data=0x80208000,sector_offset=0x10000,sector_size=0x10000!
BL: sto_read Done!
vdec_1st_pic<1268>
into VDEC_FIRST_PIC = 1362
tick 1
Enter ap_channel_play_current_channel,time=1441
epg error, not find service 0 0 0 when check finish
0110-00-08 03:55:28--sys_tdt_sectime=1262922928
flash offset = 996
