  • 4992阅读
HTV903 刷机信息,砖头,成功,不成功,检验情况都有 [复制链接]
楼主    lackey2010 发表于: 2010-01-09 09:28:41
Application Initialize...
Serial FLASH on board!
Begin write data to target range...Done
Begin verify target range...Done
Finished, reboot!
//以上信息显示后,变成了砖头,得用编程器重写才可以了。变砖头是因为刷机里偏移没有改成0,而是保留了原来的10000
Burn param error: source 0x80080000, offset 0x7fffffff, length 0x200000, FLASH size 0x100000, exit!
Finished, reboot!
BL: Initialize... Ver: bl-abs_20090701
tick = 88491772
BL: Jump to app...
flash offset = 65100
APRO 0
set to NIM_POLAR_LEFT
Current Software Date:2009.07.02,Ram Size=0x800000
No match: 261-1-0
BL: Before sto_read dev=0x80143000,data=0x802dd000,sector_offset=0x10000,sector_size=0x10000!
BL: sto_read Done!
vdec_1st_pic<1032>
into VDEC_FIRST_PIC = 1126
tick 1
system time ==1199145600
Enter ap_channel_play_current_channel,time=1211
vol compensate = 0
epg error, not find service 1 1 3eb when check finish
Enter wm_common_main,time=197471035 Press Key?
pe_warn: pe already in PE_STATE_STOP state!
vdec_1st_pic<3227>
into VDEC_FIRST_PIC = 3228
//以上信息是说的升级失败。数据长度不正确。
Burn param error: source 0x80080000, offset 0x7fffffff, length 0x100000, FLASH size 0x100000, exit!
Finished, reboot!
tick = 88403974
BL: Jump to app...
flash offset = 65116
APRO 0
BL: sto_read Done!
vdec_1st_pic<1031>
tick 1
vol compensate = 0
Enter wm_common_main,time=197392931 Press Key?
vdec_1st_pic<3223>
into VDEC_FIRST_PIC = 3223
vdec_1st_pic<3227>
//以上也是升级失败。
Finished, reboot!
tick = 88399516
BL: Jump to app...
APRO 0
No match: 261-1-0
BL: sto_read Done!
vdec_1st_pic<1031>
tick 1
vol compensate = 0
Enter wm_common_main,time=197481271 Press Key?
vdec_1st_pic<3231>
into VDEC_FIRST_PIC = 3231
//升级成功
Finished, reboot!
tick = 88401166
BL: Jump to app...
flash offset = 0
flash offset = 16
flash offset = 32
flash offset = 56
flash offset = 80
flash offset = 104
flash offset = 140
flash offset = 788
flash offset = 820
flash offset = 844
APRO 0
BL: Before sto_read dev=0x80143000,data=0x8020c000,sector_offset=0x10000,sector_size=0x10000!
BL: sto_read Done!
vdec_1st_pic<4480>
into VDEC_FIRST_PIC = 4574
tick 4
Enter ap_channel_play_current_channel,time=4655
epg error, not find service 0 0 0 when check finish
//改动数据刷机
