  • 12696阅读
GX3001+GX1121+rda5812,用GxUpdate 2.3.5可读出的信息,但GxDownloaderIII_V1.008备份不了。 [复制链接]
楼主    jonesttt 发表于: 2010-01-14 18:37:25
本人机子GX3001+GX1121+rda5812,升级口只在三针,分别为TX,RX,GND,直连电脑com口,用GxDownloaderIII_V1.008工具备份不了,设置都是按照教程上的:chip type:GX3001 ,Xtal:4MHZ ,Flash interface: SPI-Flash ,Section :sysdb或key .先点dump,再开机顶盒电源,进度条没有显示进度,只是进度条上英文显示:send bootload bin   。
如果用卓异的升级工具GxUpdate 2.3.5 for ZhuoYi 有反应,机顶盒通电后能读出数据,如下:
[valid code in serial flash]
[start]panel OK jiademei
[Enter the flash init]
==step1==
[init]--check sysdb, ok
==step2==
step2: no force key
step2: download_flag == 0, entry step3
==step3==
step3: flash head crc pass, entry step4
==step4==
step4: load zip app soft
step4: app soft crc pass, #normal start#
Uncompressing begin...
Done, booting the app soft.
GXAUDIO_PT8211
GX1121 V1.73 Build20090625
[RF]--rda5812
[REMOTE] STD
[Dbase] Initial SysDbase ...OK!
[Dbase] UsrDbase Initialize...Ok!
[Dbase] UsrDbase Loading...Ok!
[Dbase] UsrDbase querying...
[Dbase] Current Status: Total:65536, Used:2464, Frag:168
[init]--panel OK jiademei
###0x40004038 = 0x23c00,0x4000403c = 0xcb###
[ STB_APP ] eit START
[STB_APP] reserve gxapp_set_current_service_id:current_service_id=0x3e9
[AV] Play channel_num=01000001, service_id=0x3e9,service_name=CCTV-1
[Tuner] frequency=11880, polar=0, symbol_rate=28800
[AV]volume_db :25,offset:+0
[AV] pcr_pid=0x834
[AV] video_pid=0x834
[AV] audio_pid=0x835
[Tuner] Lost!! freq=11880,QAM=0,Sym/s=28800
^_^ R[1] KeyValue == 65554     i == 0
[STB_APP] gxapp_set_current_service_id:current_service_id=0x3eb
[AV] Play channel_num=01000002, service_id=0x3eb,service_name=CCTV-7
[AV] pcr_pid=0x848
[AV] video_pid=0x848
[AV] audio_pid=0x849
可以看到读出了GX1121和rda5812等信息,但为什么用GxDownloaderIII_V1.008工具备份不了,没有反应,请高人指点。
