  • 3117阅读
三星数码王 668C刷机求助 [复制链接]
yundal
楼主    yundal 发表于: 2010-01-18 10:42:57
刷机后显示有错误,求助啊?请问到底成功了没有
提示如下:
Application Initialize... Ver: bt-cl-20090112
Serial FLASH on board!
Begin write data to target range...Done
Begin verify target range...Done
Finished, halt!
BL: Initialize... Ver: bl-abs_20090521
tick = 149119783
BL: Jump to app...
flash offset = 50612
APRO 0
set to NIM_POLAR_LEFT
channel_change: tunerPllOffset=0
Current Software Date:2010.01.06,Ram Size=0x800000
BL: Before sto_read dev=0x8012e8b0,data=0x8023e028,sector_offset=0x10000,sector_size=0x10000!
BL: sto_read Done!
No match: 261-1-0
tick 2
system time ==1199145600
Enter ap_channel_play_current_channel,time=2623
vol compensate = 0
[b]epg error, not find service 1 1 3ea when check finish
epg error, not find service 1 1 3ea when check finish[/b]
Enter wm_common_main,time=236490232 Press Key?
pe_warn: pe already in PE_STATE_STOP state!
VDEC_FIRST_PIC
