  • 2881阅读
华亚写入显示这样是怎么了 高手进 [复制链接]
楼主    as569368280 发表于: 2011-09-08 09:34:44
写入数据完成!
Application Initialize...
Serial FLASH on board!
Begin write data to target range...Done
Begin verify target range...Done
Finished, reboot!
BL: Initialize... Ver: bl-abs_20090105
BL: download_flag is 0!Check application!
BL: Load Application to run!
BL: Jump to application...
--11111----0014: 3c000000
APRO 0
[Function:tuner_identify,Line:93] regValue[0] = 0x0,=0x0!
[Function:ts2000_ts2020_identify,Line:55] reg_0x00 = 0x1!
[Function:ts2000_ts2020_identify,Line:59] reg_0x62 = 0x0!
set to NIM_POLAR_LEFT
A1108_ITuner_GetLockStatus = 0
Current Software Date:2010.12.24,Ram Size=0x800000
BL: Before sto_read dev=0x801508d8,data=0x8016cc30,sector_offset=0x10000,sector_size=0x10000!
BL: sto_read Done!
tick 3
system time ==1199145600
 Enter ap_channel_play_current_channel,time=3025
ap_channel.c : tp.lnb_type = 0,tp.polar=3!
ap_channel.c : tp.lnb_freq2 = 0,tp.freq=12100!
ap_channel.c : nci.frequency = 12100!
set to NIM_POLAR_RIGHT
--------Tuner Set Freq(12100) & symbolrate(28800) out of range ------
VID=2260,AUD=2261,PCR=2260
vol compensate = 0
epg error, not find service 1 2 3f9 when check finish
 Enter wm_common_main,time=300565208 Press Key?
pe_warn: pe already in PE_STATE_STOP state!
VDEC_FIRST_PIC
