  • 3248阅读
usb转com连奥伟 ABS-900E出现的问题 [复制链接]
kaile
楼主    kaile 发表于: 2010-01-21 17:03:06
找了个usb转com的线连接到接收机的9芯插口,用超级终端还有串口调试出现的都是这个
lash Size:0x200000
tsloader_main:Feb 17 2009,15:20:32
...***** Check DEVICE INFO *****
***** Check FLASH HEADER INFO *****
***** Check NVRAM INFO *****
Boot APP from Flash app type=1
Start App Dram ......
### io config initial ########
HW_IR_NEC
DEV_KD_Initial Ok
System Heap Size = 10415256
lnb power overload irq enable failed!
AVL1108 VerInfo.Chip.Major=2 Minor=1 Build=1
AVL1108 API.Chip.Major=3 Minor=2 Build=2
AVL1108 Patch.Chip.Major=4 Minor=1 Build=32
>> Read NVRAM Success
>> MenuBmp_LoadPalette() : True
System Time Created
SysTimeSemaphore Created
ch_sw task Created
>> NIM : EN_NIM_TASK_STATE_SET_CHANNEL
A1108_ISharpTuner_GetLockStatus Fail!
A1108_IABSRx_GetLockStatus failed
>>ap_ch_switch_lastgoodst_FlashHeader_Info.magic_key=0x1 2345678,software_version=0xc9,AS_CRC32=0x45c9381b,Flash_Header_CRC32=0xe1332d75
st_FlashHeader_Info.downloadtime=0xd5ef000
>> [USRDEBUG] DVB_DebugInitial success
========= Normal Play Init ========
CDAT >>
CDAT >>
****CT***** A1108_IABSRx_GetLockStatus FAIL********!
( A1108_ISharpTuner_GetLockStatus Fail!
)不断出现 没法连接请帮我看看是怎么回事 谢谢了
