  • 4378阅读
华亚鸡自动搜索时的程序表,看BIN看累了来看看这个 [复制链接]
占线
级别: Mod
楼主    占线 发表于: 2010-01-27 22:29:01
机型HTV903F+ABS(HR3121)+AV2020
电脑联机刷机后开自动搜索时,监视屏幕里出现的数据,我看不懂,拿来给大家看看
pe_warn: pe already in PE_STATE_STOP state!
set to NIM_POLAR_LEFT
nim_hi3121_set value= 1
ap_post_key:16
ap_post_key:4?6
ap_post_key:17
nim_hi3121_set value= 0
flash offset = 18580
flash offset = 20604
flash offset = 20620
freq = 1090MHz, sym = 28800, polar = 2flash offset = 20692
ap_post_key:4017
pat back!
DOV<10000000>
ch<1c> data broken
PSIOV<1c>
sdt back!
flash offset = 20720
flash offset = 20752
flash offset = 20808
freq = 1130MHz, sym = 28800, polar = 2hi3121Decode(): In Line:328   carrFreq = 1130, symbolRate = 28800!
In hi3121Decode():In Line:393!
flash offset = 20880
pat back!
sdt back!
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
pg name = CCTV-1
flash offset = 20908
vol comp = 0
vol comp = 0
pg name = CCTV-7
flash offset = 21032
vol comp = 0
vol comp = 0
pg name = 拇ǹ蛋筒赜?
flash offset = 21160
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
pg name = 西藏汉?
flash offset = 21292
vol comp = 0
pg name = 西藏藏?
flash offset = 21428
vol comp = 0
flash offset = 21568
freq = 1170MHz, sym = 28800, polar = 2hi3121Decode(): In Line:328   carrFreq = 1170, symbolRate = 28800!
flash offset = 21644
pat back!
sdt back!
vol comp = 0
vol comp = 0
vol comp = 0
pg name = 内晒盼朗?
flash offset = 21672
vol comp = 0
pg name = 内蒙古捎锲档?
flash offset = 21816
vol comp = 0
vol comp = 0
vol comp = 0
pg name = 吉殖锲档?
flash offset = 21964
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
pg name = 陆河?
flash offset = 22116
vol comp = 0
pg name = 新疆维?
flash offset = 22272
vol comp = 0
pg name = 新疆哈?
flash offset = 22432
vol comp = 0
flash offset = 22596
freq = 1210MHz, sym = 28800, polar = 2hi3121Decode(): In Line:328   carrFreq = 1210, symbolRate = 28800!
flash offset = 22676
pat back!
sdt back!
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
pg name = 青海藏语
flash offset = 22704
vol comp = 0
flash offset = 22872
flash offset = 22944
epg error, not find service 0 0 0 when check finish
flash offset = 22968
flash offset = 23000
flash offset = 23032
osal_timer_start
ap_post_key:12
hi3121Decode(): In Line:328   carrFreq = 1090, symbolRate = 28800!
flash offset = 23068
ap_post_key:4012
vol compensate = 0
PCR<f65b2756>STC<f5682ef9>DIFF<f2f85d>WAIT
PCR<f65b2e03>STC<f56835a7>DIFF<f2f85c>RST
epg error, not find service 1 1 3e9 when check finish
vdec_1st_pic<16513>
into VDEC_FIRST_PIC = 16514
[Pf]:<stc:f65bb229-pts:f65c28e3=000076ba>
[Pf]:<stc:f65bb930-pts:f65c28e3=00006fb3>
[Pf]:<stc:f65bc039-pts:f65c28e3=000068aa>
[Pf]:<stc:f65bc740-pts:f65c28e3=000061a3>
[Pf]:<stc:f65bce49-pts:f65c28e3=00005a9a>
[Pf]:<stc:f65bd551-pts:f65c28e3=00005392>
[Pf]:<stc:f65bdc58-pts:f65c28e3=00004c8b>
[Pf]:<stc:f65be360-pts:f65c28e3=00004583>
[Pf]:<stc:f65bea69-pts:f65c28e3=00003e7a>
[Pf]:<stc:f65bf170-pts:f65c28e3=00003773>
[Pf]:<stc:f65bf879-pts:f65c28e3=0000306a>
[Pf]:<stc:f65bff80-pts:f65c28e3=00002963>
[Pf]:<stc:f65c0689-pts:f65c28e3=0000225a>
[Pf]:<stc:f65c0d90-pts:f65c28e3=00001b53>
[Pf]:<stc:f65c1499-pts:f65c28e3=0000144a>
ap_post_key:12
ap_post_key:4012
ap_post_key:17
epg error, not find service 1 1 3e9 when get event num
ap_post_key:4017
ap_post_key:12
ap_post_key:4012
ap_post_key:e
flash offset = 23100
vdec_1st_pic<22046>
into VDEC_FIRST_PIC = 22046
flash offset = 23132
ap_post_key:400e
epg error, not find service 0 0 0 when get event num
ap_post_key:f
ep! error, not find service 0 0 0 when get event num
ap_post_key:400f
ap_post_key:e
osal_timer_start
flash offset = 23164
flash offset = 23196
first_pic_got = 0
vol compensate = 0
ap_post_key:400e
epg error, not find se講ice 1 1 3e9 when get event num
vdec_1st_pic<-21745>
into VDEC_FIRST_PIC = -21744
[Pf]:<stc:f6860551-pts:f68658e3=00005392>
[Pf]:<stc:f6860c58-pts:f68658e3=00004c8b>
[Pf]:<stc:f6861361-pts:f68658e3=00004582>
[Pf]:<stc:f6861a69-pts:f68658e3=00003e7a>
[Pf]:<stc:f6862171-pts:f68658e3=00003772>
[Pf]:<stc:f6862879-pts:f68658e3=0000306a>
[Pf]:<stc:f6862f81-pts:f68658e3=00002962>
[Pf]:<stc:f6863688-pts:f68658e3=0000225b>
[Pf]:<stc:f6863d91-pts:f68658e3=00001b52>
[Pf]:<stc:f6864498-pts:f68658e3=0000144b>
ap_post_key:10
ap_post_key:4010
ap_post_key:16
ap_post_key:4016
ap_post_key:16
ap_post_key:4016
ap_post_key:16
ap_post_key:4016
ap_post_key:17
ap_post_key:4017
APRO 10
ap_post_key:d
ap_post_key:400d
ap_post_key:d
ap_post_key:400d
ap_post_key:d
ap_post_key:400d
apwpost_key:d
ap_post_key:400d
ap_post_key:17
first_pic_got = 0
ap_post_key:4017
ap_post_key:16
ap_post_key:4016
ap_post_key:17
flash offset = 23228
flash offset = 25252
flash offset = 25556
freq = 1090MHz, sym = 28800, polar = 2flash offset = 25628
ap_post_key:4017
pat back!
DOV<10000000>
ch<1c> data broken
PSIOV<1c>
sdt back!
flash offset = 25656
flash offset = 25688
flash offset = 25744
flash offset = 25816
pat back!
osal_timer_start
sdt back!
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
pg nsdt back!
vol comp = 0
vol comp = 0
vol comp = 0
pg name = 内晒盼朗?
flash offset = 26608
vol comp = 0
pg name = 内蒙古捎锲档?
flash offset = 26752
vol comp = 0
vol comp = 0
vol comp = 0
pg name = 吉殖锲档?
flash offset = 26900
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
pg name = 陆河?
flash offset = 27052
vol comp = 0
pg name = 新疆维?
flash offset = 27208
vol comp = 0
pg name = 新疆哈?
flash offset = 27368
vol comp = 0
flash offset = 27532
flash offset = 27612
pat back!
sdt back!
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
pg name = 青海藏?
flash offset = 27640
vol comp = 0
flash offset = 27808
flash offset = 27880
flash offset = 27904
flash offset = 27936
flame = CCTV-1
flash offset = 25844
vol comp = 0
vol comp = 0
pg name = CCTV-7
flash offset = 25968
vol comp = 0
vol comp = 0
pg name = 拇ǹ蛋筒赜?
flash offset = 26096
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
vol comp = 0
pg name = 西藏汉?
flash offset = 26228
vol comp = 0
pg name = 西藏藏?
flash offset = 26364
vol comp = 0
flash offset = 26504
flash offset = 26580
pat back!
