  • 5717阅读
请教编译错误 [复制链接]
楼主    yanzhongsan 发表于: 2012-04-24 10:39:01
各位好:
我手上有一份SPHE8104GW的源码,但是一直编译失败,在链接的时候老是报错说缺少库文件,请问如何解决啊
错误内容:
D:\relase>1 16
找不到 D:\relase\ir_vfd\libir.a
"mkdep rsm_upd.c"
"mkdep rw_nvmem.c"
"mkdep vfd.c"
"mkdep time.c"
"mkdep bit_rate.c"
"mkdep ircmd.c"
"mkdep ir_parser.c"
"mkdep ir_filter.c"
"mkdep ir_drv.c"
"mkdep resume.c"
"compile resume.c"
"compile ir_drv.c"
"compile ir_filter.c"
"compile ir_parser.c"
In file included from ir_parser.c:718:
../car_uart.c: In function `intr_uart0_fifo_2':
../car_uart.c:39: warning: unused variable `buffer'
../car_uart.c: In function `wendu_value':
../car_uart.c:256: warning: control reaches end of non-void function
../car_uart.c: In function `show_alarm_luntai':
../car_uart.c:275: warning: implicit declaration of function `osd_draw_main_rect
../car_uart.c:279: warning: implicit declaration of function `qiya_value'
../car_uart.c:295: warning: implicit declaration of function `qiya_max'
../car_uart.c:317: warning: implicit declaration of function `qiya_min'
../car_uart.c: In function `polling_car_info':
../car_uart.c:420: warning: suggest parentheses around comparison in operand of
../car_uart.c:452: warning: implicit declaration of function `xuema_receiver'
../car_uart.c:454: warning: implicit declaration of function `weihu_xuema_receiv
er'
../car_uart.c:456: warning: implicit declaration of function `weihu_taya_wendu_r
eceiver'
../car_uart.c:475: warning: implicit declaration of function `ir_ui_change'
../car_uart.c:524: warning: empty body in an if-statement
../car_uart.c:531: warning: empty body in an if-statement
../car_uart.c:537: warning: suggest parentheses around + or - inside shift
../car_uart.c:666: warning: unused variable `temp_luntai'
../car_uart.c:411: warning: unused variable `Tem_press_data_buff'
../car_uart.c: In function `polling_car_500ms':
../car_uart.c:746: warning: implicit declaration of function `return_normal_stat
e'
../car_uart.c:718: warning: unused variable `buffer'
../car_uart.c: At top level:
../car_uart.c:900: warning: type mismatch with previous implicit declaration
../car_uart.c:682: warning: previous implicit declaration of `osd_draw_main_rect
../car_uart.c:900: warning: `osd_draw_main_rect' was previously implicitly decla
red to return `int'
../car_uart.c: In function `show_car_icon':
../car_uart.c:916: warning: unused variable `start1'
../car_uart.c: In function `check_car_key':
../car_uart.c:1042: warning: unused variable `j'
../car_uart.c:1042: warning: `keydata' might be used uninitialized in this funct
ion
ir_parser.c: In function `ircmd_pre_paser':
ir_parser.c:723: warning: unused variable `kkkk'
"compile ircmd.c"
"compile bit_rate.c"
"compile time.c"
time.c: In function `Mp3_ChkSkipData':
time.c:672: warning: implicit declaration of function `show_id3_song'
"compile vfd.c"
"compile rw_nvmem.c"
"compile rsm_upd.c"
"update library.."
"libir.a made"
已复制       1 个文件。
找不到 D:\relase\*.obj
找不到 D:\relase\rom.bin
找不到 D:\relase\romL.bin
Get SUNPLUS_DVD
Use model GENERAL_8104G_VIDEO_64_CAR
Check .\\Customers\\Sunplus\\cfg_customers_8104G_CAR_video_64.h
Do not use Chinese fonts!!
"mkdep cust_nav.c"
"mkdep dsp3_intr.c"
"mkdep dsp3_if.c"
"mkdep audif.c"
"mkdep dsp3_config.c"
"mkdep ninf.c"
"mkdep kernel.c"
"mkdep kfptr.c"
"mkdep kinf.c"
"mkdep ioprom.c"
"mkdep iop.c"
"mkdep spi_duplex_fresh_send_data.c"
"mkdep spi_duplex_fs_upgrade.c"
"mkdep spi_duplex_mcu_upgrade.c"
"mkdep spi_duplex_parser_data_api.c"
"mkdep spi_duplex_crc.c"
"mkdep spi_duplex_process.c"
"mkdep spi_data_packge_process.c"
"mkdep spi_process.c"
"mkdep uart_communication.c"
"mkdep applause.c"
"mkdep flash_if.c"
"mkdep gps_GUI.c"
"mkdep touch_panel.c"
"mkdep atapi_.c"
"mkdep TVGApp.c"
"mkdep c_i2c.c"
"mkdep cdplayer.c"
"mkdep LanguageUtil.c"
"mkdep virtual_keyboard.c"
"mkdep userlogo.c"
"mkdep gpio.c"
"mkdep audctrl.c"
"mkdep ampvol.c"
"mkdep radio.c"
"mkdep ircode.c"
"mkdep osdfont_decompress.c"
"mkdep double_title.c"
"mkdep score.c"
"mkdep UartComm.c"
"mkdep safe.c"
"mkdep browse_func.c"
"mkdep search.c"
"mkdep book.c"
"mkdep disp.c"
"mkdep setup_dsp_config.c"
"mkdep setup_ui1.c"
"mkdep setup_str.c"
"mkdep setup.c"
"mkdep prog.c"
"mkdep read.c"
"mkdep font_offset.c"
"mkdep OSDShowFont.c"
"mkdep databuf.c"
"mkdep title.c"
"mkdep sound.c"
"mkdep emuio.c"
"mkdep membufv.c"
"mkdep membuf.c"
"mkdep zoomfact.c"
"mkdep dvd_vr_func.c"
"mkdep license.c"
"mkdep sysmain2.c"
"compile sysmain2.c"
"compile license.c"
"compile dvd_vr_func.c"
"compile zoomfact.c"
"compile membuf.c"
"compile membufv.c"
"compile emuio.c"
"compile sound.c"
"compile title.c"
"compile databuf.c"
"compile OSDShowFont.c"
"compile font_offset.c"
"compile read.c"
"compile prog.c"
"compile SETUP/setup.c"
"compile SETUP/setup_str.c"
"compile SETUP/setup_ui1.c"
"compile SETUP/setup_dsp_config.c"
"compile disp.c"
"compile book.c"
"compile search.c"
"compile browse_func.c"
"compile safe.c"
"compile UartComm.c"
"compile score.c"
"compile double_title.c"
"compile osdfont_decompress.c"
"compile IR_VFD/ircode.c"
"compile radio.c"
"compile ampvol.c"
"compile audctrl.c"
"compile gpio.c"
"compile userlogo.c"
"compile virtual_keyboard.c"
"compile LanguageUtil.c"
"compile cdplayer.c"
"compile c_i2c.c"
"compile TVGApp.c"
"compile atapi_.c"
"compile touch_panel.c"
"compile gps_GUI.c"
"compile flash_if.c"
"compile applause.c"
"compile uart_communication.c"
"compile spi_protocol/spi_process.c"
"compile spi_protocol/spi_data_packge_process.c"
"compile spi_duplex_protocol/spi_duplex_process.c"
"compile spi_duplex_protocol/spi_duplex_crc.c"
"compile spi_duplex_protocol/spi_duplex_parser_data_api.c"
"compile spi_duplex_protocol/spi_duplex_mcu_upgrade.c"
"compile spi_duplex_protocol/spi_duplex_fs_upgrade.c"
"compile spi_duplex_protocol/spi_duplex_fresh_send_data.c"
"compile IOP/iop.c"
"compile IOP/ioprom.c"
"compile kinf.c"
"compile kfptr.c"
"compile kernel.c"
"compile ninf.c"
"compile DSP3/dsp3_config.c"
"compile audif.c"
"compile DSP3/dsp3_if.c"
"compile DSP3/dsp3_intr.c"
"compile cust_nav.c"
"assemble intdrv.S"
"assemble init0.S"
"assemble crt0.S"
"compile rominit.c"
"assemble boot_flashs.S"
"generate linker script"
"linking.."
d:\gccl2\bin\..\lib\gcc-lib\mipsel-elf\3.2.1\..\..\..\..\mipsel-elf\bin\ld.exe:
cannot find -lsys_8202
collect2: ld returned 1 exit status
make: *** [romL.obj] Error 1
Failed on generating rom.bin
