  • 5077阅读
51单片机C语言编程基础及实例之五[数码管驱动] [复制链接]
rkvclu
楼主    rkvclu 发表于: 2008-06-16 15:17:23
数码管驱动
显示“12345678”
P1端口接8联共阴数码管SLED8的段极:P1.7接段h,…,P1.0接段a
P2端口接8联共阴数码管SLED8的段极:P2.7接左边的共阴极,…,P2.0接右边的共阴极
方案说明:晶振频率fosc=12MHz,数码管采用动态刷新方式显示,在1ms定时断服务程序中实现
代码
#include <at89x92.h>
unsigned char DisBuf[8]; //全局显示缓冲区,DisBuf[0]对应右SLED,DisBuf[7]对应左SLED,
void DisplayBrush( void )
{ code unsigned char cathode[8]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f}; //阴极控制码
Code unsigned char Seg7Code[16]= //用十六进数作为数组下标,可直接取得对应的七段编码字节
{0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
static unsigned char i=0; // (0≤i≤7) 循环刷新显示,由于是静态变量,此赋值只做一次。
P2 = 0xff; //显示消隐,以免下一段码值显示在前一支SLED
P1 = Seg7Code[ DisBuf[i] ]; //从显示缓冲区取出原始数据,查表变为七段码后送出显示
P2 = cathode[ i ];   //将对应阴极置低,显示
if( ++i >= 8 ) i=0; //指向下一个数码管和相应数据
void Timer0IntRoute( void ) interrupt 1
TL0 = -1000; //由于TL0只有8bits,所以将(-1000)低8位赋给TL0
TH0 = (-1000)>>8; //取(-1000)的高8位赋给TH0,重新定时1ms
DisplayBrush();
void Timer0Init( void )
{ TMOD=(TMOD & 0xf0) | 0x01; //初始化,定时器T0,工作方式1
TL0 = -1000; //定时1ms
TH0 = (-1000)>>8;
TR0 = 1;   //允许T0开始计数
ET0 = 1;   //允许T0计数溢出时产生中断请求
void Display( unsigned char index, unsigned char dataValue ){ DisBuf[ index ] = dataValue; }
void main( void )
unsigned char i;
for( i=0; i<8; i++ ){ Display(i, 8-i); } //DisBuf[0]为右,DisBuf[7]为左
Timer0Init();
EA = 1;   //允许CPU响应中断请求
While(1);
