  • 3296阅读
大师看看这个华亚机器刷不了 [复制链接]
楼主    yuwenliu 发表于: 2012-11-13 09:47:19
华亚大板,903 1108 2晶十线,刷不了,软件提示如下:
Application Initialize...
Serial FLASH on board!
Begin write data to target range...Done
Begin verify target range...Done
Finished, reboot!
BL: Initialize... Ver: bl-abs_20090105
BL: download_flag is 0!Check application!
BL: Load Application to run!
BL: Unzip error!
BL: Entry is NULL!
BL: Load fail, reboot. 0x0000:0x0000
BL: Jump to application...
--11111----0014: 3c000000
APRO 0
set to NIM_POLAR_LEFT
frequency=0x1090,     Temp=0x2880
A1108_ITuner_GetLockStatus = 0
A1108_IABSRx_LockChannel = 0
Current Software Date:2010.11.29,Ram Size=0x800000
No match: 261-1-0
BL: Before sto_read dev=0x8013d870,data=0x80176f80,sector_offset=0x10000,sector_size=0x10000!
BL: sto_read Done!
tick 2
system time ==1199145600
Enter ap_channel_play_current_channel,time=2547
frequency=0x1170,     Temp=0x2880
vol compensate = 0
epg error, not find service 1 2 3f8 when check finish
Enter wm_common_main,time=230691691 Press Key?
pe_warn: pe already in PE_STATE_STOP state!
VDEC_FIRST_PIC
A1108set to NIM_POLAR_LEFT
set to NIMset to NIM_POLAR_LEFT
_set to NIM_POLAR_LEFT
POLAR_LEFT
A1108_IAset to NIM_POLAR_LEFT
