  • 3054阅读
MCU_Program_with_TDA7540收音机程序 [复制链接]
acetuo
楼主    acetuo 发表于: 2013-01-28 16:40:08
[sell=1]MCU_Program_with_TDA7540
TDA7540 收音机程序,单片机为ST的,程序结构很不错的,可以参考一下,第一次上载,支持一下-TDA7540 radio procedures, single-chip for ST, and program structure is very good, you can refer to the first upload, support for some
ST7 MCU Program with TDA7540
............................\release note.txt
............................\Software
............................\........\IDE
............................\........\...\CONFIG
............................\........\...\......\Debug
............................\........\...\......\Default.env
............................\........\...\......\TDA7540.mak
............................\........\...\......\TDA7540.prm
............................\........\...\......\tda7540.stp
............................\........\...\......\tda7540.stw
............................\........\...\......\tda7540.wed
............................\........\...\......\Version.h
............................\........\...\......\Version.h.bak
............................\........\...\Insight
............................\........\...\OBJECT
............................\........\...\......\adc_drv.o
............................\........\...\......\Aud_main.o
............................\........\...\......\disp.o
............................\........\...\......\eeprom_24C02.o
............................\........\...\......\I2c_user.o
............................\........\...\......\inter.o
............................\........\...\......\key.o
............................\........\...\......\libr.o
............................\........\...\......\power.o
............................\........\...\......\radio.o
............................\........\...\......\radio_pll.o
............................\........\...\......\st72321.o
............................\........\...\......\start.o
............................\........\...\......\TDA7540.abs
............................\........\...\......\TDA7540.BIN
............................\........\...\......\TDA7540.HEX
............................\........\...\......\TDA7540.MAP
............................\........\...\......\TDA7540.o
............................\........\...\......\TDA7540.S19
............................\........\...\......\tuner.o
............................\........\...\SOURCE
............................\........\...\......\Aud_main.c
............................\........\...\......\AUD_MAIN.H
............................\........\...\......\Disp.c
............................\........\...\......\Disp.h
............................\........\...\......\Key.c
............................\........\...\......\Key.h
............................\........\...\......\LIB
............................\........\...\......\...\Adc_drv.c
............................\........\...\......\...\ADC_DRV.H
............................\........\...\......\...\eeprom_24C02.c
............................\........\...\......\...\EEPROM_24C02.h
............................\........\...\......\...\I2c_user.c
............................\........\...\......\...\I2c_user.h
............................\........\...\......\...\Inter.c
............................\........\...\......\...\Inter.h
............................\........\...\......\...\Libr.c
............................\........\...\......\...\Libr.h
............................\........\...\......\...\LIB_WAIT.H
............................\........\...\......\...\ref_freq_table.txt
............................\........\...\......\...\St72321.c
............................\........\...\......\...\St72321.h
............................\........\...\......\...\system.h
............................\........\...\......\...\Tuner.c
............................\........\...\......\...\TUNER.H
............................\........\...\......\...\VSSVER.SCC
............................\........\...\......\LUSTART.H
............................\........\...\......\Power.c
............................\........\...\......\Power.h
............................\........\...\......\Radio.c
............................\........\...\......\Radio.h
............................\........\...\......\Radio_pll.c
............................\........\...\......\Radio_pll.h
............................\........\...\......\START.C
............................\........\...\......\TDA7540.c
............................\........\...\......\TDA7540.h
............................\........\...\......\VSSVER.SCC[/sell]
