  • 4059阅读
澜起刷机问题求助【已解决】请别再跟帖回复,谢谢! [复制链接]
gmh79
楼主    gmh79 发表于: 2014-09-17 13:06:18
试用多个澜起工具对手上一台中九刷机,都不能成功刷机,澜起4.7提示如下
Please reset the STB!
Got sync byte!
Start sending client...
Start to check serial...
Inform slave OK!
Prepare to download...
Start downloading data...
End downloading!
Slave respose OK!
Verify burning flash...
Start burning flash, DONOT POWOFF!
Burning flash OK!
Current UPG exit+++++++!
Current UPG exit--------!FBw1d2
soft_ver is 5485
g24 = 1, g25 = 1
GPIO_PANEL
hw check invalid
TS2022
0Xd5
extand init done.
澜起小蝴蝶提示:
请重启 STB ....
同步中...
请稍等,正在发送 client...
开始写入数据...
数据传送完成,
开始烧写存储器,请不要关机!
O?뾀钾矑矑Ϧ Â
F
Bw
1
d2
soft_ver is 5485
g24 = 1, g25 = 1
GPIO_PANEL
h
w check invalid
TS2022
0Xd5
e
xtand init done.
求解决办法,谢谢!
[b]原来是极化原因,原来这台澜启是单极化的缘故,去掉极化片45个台[/b]
