  • 4334阅读
TCL-L48F3390A-3D(MS80104)MS801机芯强制升级 [复制链接]
sky-sun
楼主    sky-sun 发表于: 2015-12-13 13:25:18
TCL-L48F3390A-3D(MS80104)MS801机芯强制升级.doc
[size=font-size:10.5pt,10.5pt][backcolor=white][color=#444444][font=宋体]先把强制升级文件:[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=#444444][font=Tahoma]MstarUpgrade.bin[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=#444444][font=宋体]复制入[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=#444444][font=Tahoma]U[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=#444444][font=宋体]盘根目录,把[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=#444444][font=Tahoma]U[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=#444444][font=宋体]盘插入[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=#444444][font=Tahoma]USB[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=#444444][font=宋体]口看图片[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=#444444][font=Tahoma],[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=#444444][font=宋体]断开[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=#444444][font=Tahoma]220V[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=#444444][font=宋体]电源,然后按着电源待机开关不要松手,再上[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=#444444][font=Tahoma]220V[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=#444444][font=宋体]电,等到面板灯闪或者[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=#444444][font=Tahoma]U[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=#444444][font=宋体]盘灯闪就松开电源待机开关,这时出现屏幕出现[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=#444444][font=Tahoma]  [/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=#444444][font=宋体]升级中。。。。期间不能关机或断电,等到大约[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=#444444][font=Tahoma]10[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=#444444][font=宋体]分钟左右灯就不闪了,机自动重启。机器会进入系统,等到系统更新完后就升级完了。升级好后左下角出现程序版本,这个要进入总线关掉(关掉方法,用带有子菜单的[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=#444444][font=Tahoma]TCL[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=#444444][font=宋体]遥控器,接子菜单进入到对比度[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=#444444][font=Tahoma],[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=#444444][font=宋体]再按数字[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=#444444][font=Tahoma]9735[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=#444444][font=宋体],把第一项的[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=#444444][font=Tahoma]ON[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=#444444][font=宋体]关掉变[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=#444444][font=Tahoma]OFF[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=#444444][font=宋体]就可以了。注意:不要按主菜单,主菜单是找不到对比度的[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=#444444][font=Tahoma])[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=#444444][font=宋体]。......................................................................................[/font][/color][/backcolor][/size]
