  • 4267阅读
学习单片机之---24C02 C51源程序 [复制链接]
jswr
楼主    jswr 发表于: 2008-08-20 15:24:04
/*                 声   明                           */
/*   本文从网上摘录而来,仅供给大家学习交流使用。文章中内容均为原创作者辛劳
24C02 C51源程序,希望对使用IIC总线编程的朋友有帮助
Posted by 光明之子 2005-8-25 12:26:05
#define uchar unsigned char
#define uint unsigned int
#i nclude <reg52.h>
#i nclude <stdio.h>
#i nclude <absacc.h>
sbit scl=P3^5; //24c02 SCL
sbit sda=P3^4; //24c02 SDA
sbit DOG=P1^7; //狗
uchar x24c02_read(uchar address); //从24c02的地址address中读取一个字节数据
void x24c02_write(uchar address,uchar info); //向24c02的address地址中写入一字节数据info
void x24c02_init();   //24c02初始化子程序
void delay1(uchar x);
void flash();
void x24c01_init();
void start();
void stop();
void writex(uchar j);
uchar readx();
void clock();
  uint i;
  for(i=0;i<x;i++);
  DOG=~DOG;
void flash()
  uchar u;
  DOG=~DOG;
void x24c02_init()
  scl=1; flash(); sda=1; flash();
void start()
  sda=1; flash(); scl=1; flash(); sda=0; flash(); scl=0; flash();
void stop()
  sda=0; flash(); scl=1; flash(); sda=1; flash();
  uchar i,temp;
  temp=j;
  for (i=0;i<8;i++){
    temp=temp<<1; scl=0; flash(); sda=CY; flash(); scl=1; flash();
  scl=0; flash(); sda=1; flash();
uchar readx()
  uchar i,j,k=0;
  for (i=0;i<8;i++){
    if (sda==1) j=1;
    else j=0;
    k=(k<<1)|j; scl=0;
  flash(); return(k);
void clock()
  uchar i=0;
  scl=1; flash();
  while ((sda==1)&&(i<255))i++;
  scl=0; flash();
  uchar i;
  start(); writex(0xa0);
  clock(); writex(address);
  clock(); start();
  writex(0xa1); clock();
  i=readx(); stop();
  delay1(10);
  return(i);
  EA=0;
  clock(); writex(info);
  clock(); stop();
  EA=1;
  delay1(50);
