  • 4335阅读
学习单片机之---24C02的程序 [复制链接]
jswr
楼主    jswr 发表于: 2008-08-20 15:42:52
24C02的程序 作者:狼魅 发表时间:2006-4-29 13:34:59
#include <reg51.h>
#define WriteDeviceAddress 0xa0
#define ReadDviceAddress 0xa1
sbit SCL=P3^7;
sbit SDA=P3^6;
void DelayMs(unsigned int number) {
unsigned char temp;
for(;number;number--) {
for(temp=112;temp!=0;temp--) {
void Start() {
SDA=1;
SCL=1;
SDA=0;
SCL=0;
void Stop() {
SCL=0;
SDA=0;
SCL=1;
SDA=1;
void Ack() {
SDA=0;
SCL=1;
SCL=0;
SDA=1;
void NoAck() {
SDA=1;
SCL=1;
SCL=0;
bit TestAck() {
bit ErrorBit;
SDA=1;
SCL=1;
ErrorBit=SDA;
SCL=0;
return(ErrorBit);
bit Write8Bit(unsigned char input) {
unsigned char temp;
for(temp=8;temp!=0;temp--) {
SDA=(bit)(input&0x80);
SCL=1;
SCL=0;
input=input<<1;
void Write24c02(unsigned char *Wdata,unsigned char RomAddress,unsigned char number) {
Start();
Write8Bit(WriteDeviceAddress);
TestAck();
Write8Bit(RomAddress);
TestAck();
for(;number!=0;number--) {
Write8Bit(*Wdata);
TestAck();
Wdata++;
Stop();
DelayMs(10);
unsigned char Read8Bit() {
unsigned char temp,rbyte=0;
SCL=1;
rbyte=rbyte<<1;
rbyte=rbyte|((unsigned char)(SDA));
SCL=0;
return(rbyte);
void Read24c02(unsigned char *RamAddress,unsigned char RomAddress,unsigned char bytes) {
Start();
TestAck();
TestAck();
Start();
Write8Bit(ReadDviceAddress);
TestAck();
while(bytes!=1) {
*RamAddress=Read8Bit();
Ack();
RamAddress++;
bytes--;
NoAck();
Stop();
void main(void)
Byte buf1[]={3,4,5,6,7,8};
Byte buf2[];
Write24c02(buf1,0,6);
Read24c02(buf2,0,6);
if(buf1[1]==buf2[1])LED1=0;
if(buf1[2]==buf2[2])LED2=0;
if(buf1[3]==buf2[3])LED3=0;
if(buf1[4]==buf2[4])LED4=0;
while(1);
