  • 5120阅读
学习单片机之---24c02读写程序(已通过测试) [复制链接]
jswr
楼主    jswr 发表于: 2008-08-20 15:55:13
24c02读写程序(已通过测试)#ifndef _24C02_H
#define _24C02_H
// 脚定义
sbit SCL = P3^7; //24c02 SCL
sbit SDA = P3^6; //24c02 SDA
// 功能函数
void x24c02_delay(char x)
int i;
for(i=0;i<x;i++);
void x24c02_start()
SDA = 1;
SCL = 1;
SDA = 0;
SCL = 0;
void x24c02_stop()
SDA=0;
SCL=1;
SDA=1;
void x24c02_writex(char j)
char i,temp;
temp=j;
for (i=0;i<8;i++)
temp=temp<<1;
SCL=0;
SDA=CY;
SCL=1;
SCL=0;
SDA=1;
char x24c02_readx()
char i,j,k=0;
SCL=0;
SDA=1;
for (i=0;i<8;i++)
SCL=1;
if (SDA==1) j=1;
else j=0;
k=(k<<1)|j;
SCL=0;
return(k);
void x24c02_clock()
char i=0;
SCL=1;
while ((SDA==1)&&(i<255))i++;
SCL=0;
void x24c02_init()
SCL = 1;
SDA = 1;
char x24c02_read(char address)
char i;
x24c02_start();
x24c02_writex(0xa0);
x24c02_clock();
x24c02_writex(address);
x24c02_clock();
x24c02_start();
x24c02_writex(0xa1);
x24c02_clock();
i=x24c02_readx();
x24c02_stop();
x24c02_delay(10);
return(i);
void x24c02_write(char address, char info)
EA=0;
x24c02_start();
x24c02_clock();
x24c02_clock();
x24c02_writex(info);
x24c02_clock();
x24c02_stop();
EA=1;
x24c02_delay(50);
void x24c02_writestr(char address, unsigned char *wdata, unsigned char wlen)
unsigned char k=0;
do
x24c02_write(address+k, *(wdata + k));
k++;
} while(k < wlen);
void x24c02_readstr(char address, unsigned char *rdata, unsigned char rlen)
unsigned char k=0;
do
rdata[k] = x24c02_read(address+k);
k++;
} while(k < rlen);
#endif
