  • 4671阅读
学习单片机之---c51写的X25045的读写程序 [复制链接]
jswr
楼主    jswr 发表于: 2008-08-20 16:24:00
c51写的X25045的读写程序
  * X25043/45 application Procedures
  * absolute one address access
WARNING: The function with '_' ahead ,user may not use it.as it
used internal
//使用函数:write_status(status) 写状态,一般写0
//clr_wchdog(void)   清看门狗
//unsigned char read_byte(address) //读一个字节
//void write_byte(address,Data)   //写一个字节
#define ALONE_COMPILE
#ifdef ALONE_COMPILE
#i nclude "INTRINS.H"
#endif
#ifndef nop2()
#define nop2() _nop_();_nop_();_nop_()
#endif
#define WREN   0x06
#define WRDI   0x04
#define RDSR   0x05
#define WRSR   0x01
#define READ   0x03
#define WRITE   0x02
//#define PORT P1
sfr PORT=0x90; //25045的4根io脚接在同一端口,本例为p1
  //请根据实际电路更改引脚定义
#define _SI 0x80 //si接在p1.3,0x80=00001000b
#define _SCK 0x40 //sck接在p1.2,0x80=00000100b
#define _SO 0x20 //so接在p1.1
#define _CS 0x10 //cs接在p1.0
#ifndef dword
#define dword unsigned long
#define word unsigned int
#define byte unsigned char
typedef union{
word w;
byte bh;
byte bl;
}WordType;
typedef union{
dword dw;
word w[2];
byte b[4];
}DwordType;
#endif
void _w_byte(Data)
char Data;
char i;
PORT &= (_SCK^0xff);
for(i=0;i<8;i++)
nop2();nop2();/////////////
if(Data & 0x80) PORT |= _SI;
else PORT &= (_SI^0xff);
PORT |=_SCK;
Data=Data<<1;
char _r_byte(void)
char i;
char result;
result=0;
for(i=0;i<8;i++)
PORT |=_SCK;
result=result<<1;
if((PORT & _SO) != 0)
  result |= 0x01;
PORT &=(_SCK^0xff);
return(result);
void write_status(status)
char status;
PORT &=(_CS^0xff);
_w_byte(status);
PORT |=_CS;
return;
void clr_wchdog(void)
PORT &= (_CS^0xff);
PORT |=_CS;
void wait_free(void)
unsigned int t;
t=3000;
while(--t);
void write_reg(_code)
char _code;
write_status(WREN);
PORT &= (_CS^0xff);
_w_byte(WRSR);
_w_byte(_code);
PORT |=_CS;
wait_free();
unsigned int address;
char result;
PORT &=(_CS^0xff); // Chip select
_w_byte((char)(address>255 ? (0x08|READ): READ));
_w_byte((char)(address & 0x00ff));
result=_r_byte();
PORT |=_CS;
  // Chip unselect
return(result);
char Data;
write_status(WREN);
PORT &= (_CS^0xff);
_w_byte((unsigned char)(address>255 ? (0x08|WRITE): WRITE));
_w_byte((unsigned char)(address & 0x00ff));
_w_byte(Data);
PORT |=_CS;
wait_free();
return;
unsigned long read_data(format,address)
unsigned char format;
DwordType result;
switch(format&0xdf)
case 'L':
result.b[0]=read_byte(address);
result.b[1]=read_byte(address+1);
result.b[2]=read_byte(address+2);
result.b[3]=read_byte(address+3);
break;
case 'D':
result.b[2]=read_byte(address);
result.b[3]=read_byte(address+1);
break;
case 'C':
result.b[3]=read_byte(address);
break;
return(result.dw);
void write_data(format,address,Data)
DwordType data* Data;
switch(format&0xdf)
case 'L':
write_byte(address , Data->b[0]);
write_byte(address+1, Data->b[1]);
write_byte(address+2, Data->b[2]);
write_byte(address+3, Data->b[3]);
break;
case 'D':
write_byte(address , Data->b[2]);
write_byte(address+1, Data->b[3]);
break;
case 'C':
write_byte(address , Data->b[3]);
break;
