  • 1867阅读
42E800A-8S01-图像有横线且偏红 [复制链接]
楼主    chengdushao 发表于: 2018-01-17 22:16:06
[b][size=font-size:10.5pt,10.5pt][backcolor=white][color=blue][font=Calibri]  42E800A-8S01-[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=blue][font=宋体]图像有横线且偏红。开机图像横线干扰且偏红,声音正常。怀疑排阻有异常,检查未发现问题。打算补焊主芯片,还是测量主芯片供电是否正常。当测量[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=blue][font=Calibri]U3/LD1117[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=blue][font=宋体]时,输入[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=blue][font=Calibri]5V[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=blue][font=宋体]正常,输出只有[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=blue][font=Calibri]1.6V[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=blue][font=宋体],与标称值[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=blue][font=Calibri]2.5V[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=blue][font=宋体]偏低,测量对地阻值无短路,决定换新块,试机电压[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=blue][font=Calibri]2.5V[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=blue][font=宋体]正常,图像也正常了,老化[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=blue][font=Calibri]OK[/font][/color][/backcolor][/size][size=font-size:10.5pt,10.5pt][backcolor=white][color=blue][font=宋体]。[/font][/color][/backcolor][/size][/b]
[b][backcolor=white][color=blue] [/color][/backcolor][/b]
