  • 3734阅读
嘉立创教学系列之:Altium Designer6转gerber文件 [复制链接]
szjlcb
楼主    szjlcb 发表于: 2018-05-02 15:51:57
[size=3][backcolor=#eff5f9][color=#444444][font=Tahoma, 'Microsoft Yahei', Simsun] 1)点击“开始”—>“Altium Designer6” 打开软件,如图[/font][/color][/backcolor][/size][img]http://www.sz-jlc.com/UploadCommonImages/2015-12-18/1450402941766.jpg[/img][size=3][backcolor=#eff5f9][color=#444444][font=Tahoma, 'Microsoft Yahei', Simsun]2)在File菜单中打开要转换的layout原始文件[/font][/color][/backcolor][/size][size=3][backcolor=#eff5f9][color=#444444][font=Tahoma, 'Microsoft Yahei', Simsun]3)放置分孔图列表字符串,点击主菜单中的Place--àString ,然后按TAB键在TEXT栏选中“Lengend”;Layer栏选择“Drilldrawing”,如图[/font][/color][/backcolor][/size][img]http://www.sz-jlc.com/UploadCommonImages/2015-12-18/1450402946439.jpg[/img] [img]http://www.sz-jlc.com/UploadCommonImages/2015-12-18/1450402950581.jpg[/img][size=3][backcolor=#eff5f9][color=#444444][font=Tahoma, 'Microsoft Yahei', Simsun]4)单位切换,按“Q”快捷键在公英制之间切换、按一次“Q”为公制;再按一次“Q”为英制。注:可以通过状态栏看到单位在“Mi”、“MM”之间切换;[/font][/color][/backcolor][/size][size=3][backcolor=#eff5f9][color=#444444][font=Tahoma, 'Microsoft Yahei', Simsun]5)开始转Gerber File,点击FileàFabrication outputsàGerber Files,如图[/font][/color][/backcolor][/size][img]http://www.sz-jlc.com/UploadCommonImages/2015-12-18/1450402954191.jpg[/img][size=3][backcolor=#eff5f9][color=#444444][font=Tahoma, 'Microsoft Yahei', Simsun]6)在弹出的菜单栏选以下参数,如图[/font][/color][/backcolor][/size][size=3][backcolor=#eff5f9][color=#444444][font=Tahoma, 'Microsoft Yahei', Simsun]Units:为inch       Format:为2:5  (注意要选2:5格式、这样转换的文件的精度比较高)[/font][/color][/backcolor][/size][img]http://www.sz-jlc.com/UploadCommonImages/2015-12-18/1450402958114.jpg[/img][size=3][backcolor=#eff5f9][color=#444444][font=Tahoma, 'Microsoft Yahei', Simsun]7)选择要转换的层及参数,点击Layers菜单在Plot layers栏选择used on ;在Mirror layers栏选All off,如图[/font][/color][/backcolor][/size][img]http://www.sz-jlc.com/UploadCommonImages/2015-12-18/1450402961615.jpg[/img][size=3][backcolor=#eff5f9][color=#444444][font=Tahoma, 'Microsoft Yahei', Simsun]8)设置分孔图层参数,点击Drill drawing菜单,在弹出的下拉菜单中设置如下参数,将Drill Drawing Plots栏Plot all used layer paris打勾,如图[/font][/color][/backcolor][/size][size=3][backcolor=#eff5f9][color=#444444][font=Tahoma, 'Microsoft Yahei', Simsun]将Drill Drawing symbols栏的符号选中为“Characters”[/font][/color][/backcolor][/size][img]http://www.sz-jlc.com/UploadCommonImages/2015-12-18/1450402965288.jpg[/img][size=3][backcolor=#eff5f9][color=#444444][font=Tahoma, 'Microsoft Yahei', Simsun]9)光圈表设置,默认情况下我们转成RS274X(内含D码格式),如图[/font][/color][/backcolor][/size][img]http://www.sz-jlc.com/UploadCommonImages/2015-12-18/1450402968898.jpg[/img][size=3][backcolor=#eff5f9][color=#444444][font=Tahoma, 'Microsoft Yahei', Simsun]10)光绘全局参数设置,默认情况下设计是圆弧的线转出去仍然上是圆弧,如将Other栏下的“use software arcs”打勾,则设计的圆弧会用线段来代替,如图[/font][/color][/backcolor][/size][img]http://www.sz-jlc.com/UploadCommonImages/2015-12-18/1450402972634.jpg[/img][size=3][backcolor=#eff5f9][color=#444444][font=Tahoma, 'Microsoft Yahei', Simsun]11)点击OK,软件自动转换出Gerber File并自动用内嵌的CAM2000软件打开转换的Gerber File。注:被转出的文件会自动将每一层导到原始文件所在的文件夹下,所以建议原始文件单独放一空文件夹中,如图[/font][/color][/backcolor][/size][img]http://www.sz-jlc.com/UploadCommonImages/2015-12-18/1450402977103.jpg[/img][size=3][backcolor=#eff5f9][color=#444444][font=Tahoma, 'Microsoft Yahei', Simsun]12)钻孔文件转换,点击FileàFabrication outputsàNC Drill Files,如图[/font][/color][/backcolor][/size][img]http://www.sz-jlc.com/UploadCommonImages/2015-12-18/1450402981183.jpg[/img][size=3][backcolor=#eff5f9][color=#444444][font=Tahoma, 'Microsoft Yahei', Simsun]13)在弹出的菜单中设置参数如图[/font][/color][/backcolor][/size][size=3][backcolor=#eff5f9][color=#444444][font=Tahoma, 'Microsoft Yahei', Simsun]Units:为inch          Format:为2 :5  (注意要选2:5格式、这样转换的文件的精度比较高)[/font][/color][/backcolor][/size][img]http://www.sz-jlc.com/UploadCommonImages/2015-12-18/1450402985590.jpg[/img][size=3][backcolor=#eff5f9][color=#444444][font=Tahoma, 'Microsoft Yahei', Simsun]14)点击OK,软件自动转换出Gerber File并自动用内嵌的CAM2000软件打开转换的Drill。注:被转出的文件会自动将每一层导到原始文件所在的文件夹下,所以建议原始文件单独放一空文件夹中;[/font][/color][/backcolor][/size][size=3][backcolor=#eff5f9][color=#444444][font=Tahoma, 'Microsoft Yahei', Simsun]15)目前转 Gerber File (RS274?)格式有一个弊端,长八角形的D码会变成圆角矩形,正八角形的D码会变成圆形,容易导致与设计文件不符;如转成 ODB++格式可以避免八角形D码变成现象;但ODB++的格式要用专用的软件才能导入:如genesis、cam350等软件输入。[/font][/color][/backcolor][/size][size=3][backcolor=#eff5f9][color=#444444][font=Tahoma, 'Microsoft Yahei', Simsun]a)点击FileàFabrication outputsàODB++ Files如图:[/font][/color][/backcolor][/size][img]http://www.sz-jlc.com/UploadCommonImages/2015-12-18/1450402990263.jpg[/img][size=3][backcolor=#eff5f9][color=#444444][font=Tahoma, 'Microsoft Yahei', Simsun]b)设置ODB++参数,点击Plot layers—>选择used on,将要转换的层打开。点击Mirror layers—>选择all off,将所有镜相的层关闭,如图[/font][/color][/backcolor][/size][img]http://www.sz-jlc.com/UploadCommonImages/2015-12-18/1450402996623.jpg[/img]
有需要做pcb线路板的 可以联系我扣扣800058249
