  • 3251阅读
如何设置PCB各软件过孔盖油 [复制链接]
szjlcb
楼主    szjlcb 发表于: 2018-09-01 10:08:22
[table][tr][td]
[color=#4a4a4a][font=微软雅黑][size=3]一.AD过孔盖油怎样正确批量性设置如下: [/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3]QQ:800058249[/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3]1.首选选择一个代表性过孔[/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3]双击过孔(via)[/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3][img]https://www.sz-jlc.com/uploadfiles/image/20180806/1533549616290043790.png[/img][/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3]2.左键单击选择这一过孔(via),然后右键Find Simillar Objects查找相似对像如下图[/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3][img]https://www.sz-jlc.com/uploadfiles/image/20180806/1533549616298045337.jpg[/img][/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3]3.注意勾选红色框选项,然后OK[/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3][img]https://www.sz-jlc.com/uploadfiles/image/20180806/1533549617684060109.jpg[/img][/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3]4.勾选下图红色框选项,关闭会话框,再次转出gerber后,阻焊层就不会出现过孔(过孔盖油)。[/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3][img]https://www.sz-jlc.com/uploadfiles/image/20180806/1533549621809061413.jpg[/img][/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3]二.Protel 99 SE过孔盖油怎样设置[/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3]1.Design---Rules[/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3][img]https://www.sz-jlc.com/uploadfiles/image/20180806/1533553082637067915.png[/img][/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3]2.Manufacturing---Solld mask expansion[/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3][img]https://www.sz-jlc.com/uploadfiles/image/20180806/1533553377480002524.png[/img][/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3][/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3]3.双击上图点亮Solder Mask Expansion ③ 区域[/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3][img]https://www.sz-jlc.com/uploadfiles/image/20180806/1533553795064015187.png[/img][/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3]4.对应修改④和⑤[/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3][img]https://www.sz-jlc.com/uploadfiles/image/20180806/1533554059459092402.png[/img][/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3]三.PADS Layout过孔盖油怎样设置[/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3]PADS Layout红圈过孔不选直接输出就OK了[/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3][img]https://www.sz-jlc.com/uploadfiles/image/20180806/1533554150208055768.png[/img][/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3]关于“过孔盖油”和“过孔开窗”此点,许多客户下单时经常会问这是什么意思,就此问题点[/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3]说明如下:[/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3]过孔盖油:1.下单上传的是pcb文件,并在下单时勾选过孔盖油,做板工艺就是过孔盖油。[/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3]2.下单上传的是gerber文件,按gerber文件生产,忽略下单勾选。[/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3][img]https://www.sz-jlc.com/uploadfiles/image/20180806/1533551528243005990.png[/img]名词简义过孔盖油,即导通孔(via)的焊环上面用油墨覆盖。过孔开窗:即导通孔(via)的焊环裸露(如元件焊盘一样裸露出来)上锡,一般可用于调试测量信号,缺点是容易造成短路。[/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3]过孔的处理方式[/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3]第一种,开窗,就是跟焊盘一样能很容易上锡 检验标准:上锡[/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3]第二种,盖油,检验标准:过锡炉及手工焊接过孔上不沾锡视合格。[/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3]  这是工艺决定的,为什么会出现过孔感觉没盖油的原因如下:因为阻焊油是液态的,过孔中间又是空的,在阻焊环上的[/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3]阻焊油经过烤的过程中很容易油进入过孔,从而导致过孔发黄的情况发生,这种情况受阻焊油的浓度,烤炉及用力度有关,[/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3]所以会出现有的上面能出现绿色,而有的出现发黄。[/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3]  第三种,塞油, 检验标准,不透光 上面一定要有油 第二种工艺存在这种问题,而对于像bga的过孔,要求是比较苛刻的,[/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3]所以有了塞油这种工艺,是对第二种的一种重要补充,塞油的工艺做法是,先把过孔全孔塞上油,堵往过孔,这样阻焊环[/size][/font][/color]
[color=#4a4a4a][font=微软雅黑][size=3]上的油,就不会流入过孔,而达到了不会出现过孔发黄的现象。目前嘉立创四,六层板接受塞油这种工艺[/size][/font][/color][/td][/tr][/table]
