  • 7075阅读
M190PW01 V0 spec ver0.2 [复制链接]
级别: Admin
楼主    kingdong 发表于: 2010-05-14 22:42:18
分享AUO的一款面板规格书供各位朋友下载参考,型号:M190PW01 V0 spec ver0.2 05-24-2006!
参数提要如下:
19英寸,WXGA COLOR TFT-LCD
2. General Description
This specification applies to the 19 inch-wide Color TFT-LCD Module M190PW01.
The display supports the WXGA+ (1440(H) x 900(V)) screen format and 16.7M colors. All input signals are 2 Channel
LVDS interface compatible.
This module does not contain an inverter card for backlight.
2.1 Display Characteristics
The following items are characteristics summary on the table under 25 ℃ condition:
Items Unit Specifications
Active Area [mm] 408.24 (H) x 255.15(V)
Pixels H x V 1440x3(RGB) x 900
Pixel Pitch [mm] 0.2835x 0.2835
Pixel Arrangement R.G.B. Vertical Stripe
Display Mode TN Mode,Normally White
White Luminance [cd/m2] 300 cd/m2 @ 6.5mA (Typ)
Contrast Ratio 800
Optical ResponseTime [msec] 5 (Typ, on/off)
Nominal Input Voltage VDD [Volt] +5.0 (Typ)
Power Consumption (VDD line + CCFL line) [Watt] 24.04(Typ)
Weight [Grams] 2500 (Typ)
Physical Size (H x V x D) [mm] 428.0(W) x 278.0(H) x 18.5(D) (Typ)
Electrical Interface Dual Channel LVDS
Surface Treatment Anti-glare type, Hardness 3H
Support Colors 16.7M colors (RGB 6-bits+HiFRC)
RoHS Compliance RoHS Compliance
