  • 12511阅读
SPI new program(SPI FLASH 编程器软件) [复制链接]
osvaldo
楼主    osvaldo 发表于: 2009-01-08 10:38:41
我希望它是有用的q
Version 1.0:
First Release, tested with ST and PM spi flash families
Version 1.2:
Device families added: Amic A25Lxx, Eon EN25Pxx, EN25Bxx, EN25Dxx, EN25Fxx
Version 1.3:
Bug fixed "hardware not present" in Help->Test Hardware menu, little issues with program going into neverending loop when programming without chip inserted (time out added)
Version 1.4:
Device families added: Winbond W25Xxx, W25Qxx
Version 1.5:
Speed improvements for spi code, minor changes in menu
Version 1.6:
Added Lock Bit editor window, corrected program layout so it now can be run at any resolution and dpi settings of your desktops
[audio05]
