  • 6901阅读
DC-DC器件DataSheet FOR ACT4060 [复制链接]
级别: Admin
楼主    kingdong 发表于: 2010-07-15 10:31:35
ATC4060设计参考文档,原厂英文版本!
FEATURES
 2A Output Current
 Up to 95% Efficiency
 4.75V to 20V Input Range
 8μA Shutdown Supply Current
 420kHz Switching Frequency
 Adjustable Output Voltage
 Cycle-by-Cycle Current Limit Protection
 Thermal Shutdown Protection
 Frequency FoldBack at Short Circuit
 Stability with Wide Range of Capacitors,
Including Low ESR Ceramic Capacitors
 SOP-8 Package
APPLICATIONS
 TFT LCD Monitors
 Portable DVDs
 Car-Powered or Battery-Powered Equipments
 Set-Top Boxes
 Telecom Power Supplies
 DSL and Cable Modems and Routers
 Termination Supplies
GENERAL DESCRIPTION
The ACT4060 is a current-mode step-down DC/DC
converter that generates up to 2A of output current
at 420kHz switching frequency. The device utilizes
Active-Semi’s proprietary ISOBCD20 process for
operation with input voltages up to 20V.
Consuming only 8μA in shutdown mode, the
ACT4060 is highly efficient with peak operating efficiency
at 95%. Protection features include cycle-bycycle
current limit, thermal shutdown, and frequency
foldback at short circuit.
The ACT4060 is available in a SOP-8 package and
requires very few external devices for operation.
