  • 4314阅读
今天用迷你终端连接了一下有线数字机顶盒 [复制链接]
bjc
楼主    bjc 发表于: 2010-08-01 10:01:52
华为C2600 ,一下子出了这么多,很是看不懂
不知道机顶盒在哪里可以买到!
EvilEyEscak_Init
CAK Read Eeprom OK and the address is = 0x320
+++++++++ [X-series CAK] +++++++++++
******** [v2.150 16-11-2007p1] **********
CAK Configuration :
00
sc_card_initialization
Card Revision :
4
          DVN CA 4.0
CAK Read Eeprom OK and the address is = 0x7d0
CAK Read Eeprom OK and the address is = 0x190
=====CCTV Key index =
00
01
=====Local Key index =
04
00
Area code :
01
05
03
00
04
00
00
00
00
00
00
00
00
00
00
00
00
00
00
00
00
00
00
00
00
Newtork code :
00
00
00
00
00
00
00
00
00
Service code :
00
00
00
00
00
00
00
00
00
Region code :
00
00
00
00
00
00
00
00
00
00
00
00
00
00
00
00
00
Zip code :
00
00
00
00
00
00
00
00
00
00
00
00
00
00
00
00
00
00
00
00
00
00
00
00
00
Attribute :
00
00
00
00
07
01
23
23
[cak_Init OK]
cak_GetSTBAttribute
STAPI5105 vserion 1.5.1
Revision History:
09/03/07 add dvbsubtitl support.
09/03/07 add void Get_stapi_version(void) in stcommon moudle.
09/03/07 stosd_PutRectangle 中Context.EnableFlickerFilter     = TRUE;
09/03/07 Enable the anti-flicker filter on dvbsubtitle
25/04/07 motify #define SIGNAL_QUEUE_SIZE to 64,because of seachange pti crash
08/05/07 motify ramcam.c,st release patch
FactoryMode REL_1.0.0 running
25/05/07 motify stos,change to 1.5.1
>25/05/07 motify stfdma,change to 2.1.1
25/05/07 motify stvid,change to 3.14.0
02/06/07 motify stblit,stdisp,stvid,stlayer,stgfxobj,compo
03/06/07 motify stblit-1.4.6,stpti flag xuhong-2007-6-3
04/06/07 formal release: motify stblit-1.4.6,stpti-7.1.0 SETFILTER ERROR,要重复set,3次以上
08/08/07 STAPI版本打印通过串口输出
08/08/07 setfilter error
08/08/07 PAL视频输出按照720*576
27/08/07 motify stblit 1.9.0修改花屏问题
27/08/07 motify stdenc 3.3.15+patch 支援5107
27/08/07 motify staud 1.1.4
27/08/07 motify NTSC Y 开始位置
01/09/07 增加 -DSTBLIT_ENABLE_MISSING_INTERRUPTIONS_WA
Detail stapi driver version
STBOOT_GetRevision=STBOOT-REL_2.17.1
STPIO_GetRevision=STPIO-REL_1.3.18
STTBX_GetRevision=STTBX-REL_2.3.6
STUART_GetRevision=STUART-REL_1.8.8
STI2C_GetRevision=STI2C-REL_2.3.2
STEVT_GetRevision=STEVT-REL_2.1.0A2
STCLKRV_GetRevision=STCLKRV-REL_5.2.0A2+patch1
STPTI_GetRevision=STPTI_DVB-REL_7.1.0
STFDMA_GetRevision=STFDMA-REL_2.1.1
STAVMEM_GetRevision=STAVMEM-REL_4.2.2
STOS_GetRevision=STOS-REL_1.6.0
STVID_GetRevision=STVID-REL_3.14.0
STLAYER_GetRevision=STLAYER-REL_3.8.1
STCOMPO_GetRevision=COMPO-REL_3.3.0
STDISP_GetRevision=STDISP-REL_2.2.0
STDENC_GetRevision=STDENC-REL_3.3.15+patch
STVTG_GetRevision=STVTG-REL_1.13.2 + patch
STVMIX_GetRevision=STVMIX-REL_2.0.5
STGXOBJ_GetRevision=STGXOBJ-REL_4.0.3
STVOUT_GetRevision=STVOUT-REL_4.0.6
STAUD_GetRevision=STAUDLT-REL_1.1.4
STBLIT_GetRevision=STBLIT-REL_1.9.0
STTST_GetRevision=REL_1.0.0
STVBI_GetRevision=STVBI-REL_1.2.2
STTTX_GetRevision=STTTX-REL_3.1.4A0
TUNER_SetFrequency(), Tuner Set 746000 6875 2 ...
cak_StopGettingECM
cak_StopGettingECM
cak_StopGettingECM
cak_StopGettingECM
cak_StopGettingECM
cak_StopGettingECM
cak_StopGettingECM
cak_StopGettingECM
cak_StopGettingECM
cak_StopGettingECM
