  • 3328阅读
[求助] 奥伟ABS-900E 9芯连不上 [复制链接]
kaile
楼主    kaile 发表于: 2010-01-22 11:38:48
boot v2.00
Flash Size:0x200000
tsloader_main:Feb 17 2009,15:20:32
...***** Check DEVICE INFO *****
***** Check FLASH HEADER INFO *****
***** Check NVRAM INFO *****
Boot APP from Flash app type=1
Start App Dram ......
### io config initial ########
HW_IR_NEC
DEV_KD_Initial Ok
System Heap Size = 10415256
lnb power overload irq enable failed!
AVL1108 VerInfo.Chip.Major=2 Minor=1 Build=1
AVL1108 API.Chip.Major=3 Minor=2 Build=2
AVL1108 Patch.Chip.Major=4 Minor=1 Build=32
>> Read NVRAM Success
>> MenuBmp_LoadPalette() : True
System Time Created
SysTimeSemaphore Created
ch_sw task Created
>> NIM : EN_NIM_TASK_STATE_SET_CHANNEL
A1108_ISharpTuner_GetLockStatus Fail!
A1108_IABSRx_GetLockStatus failed
>>ap_ch_switch_lastgoodst_FlashHeader_Info.magic_key=0x1 2345678,software_version
=0xc9,AS_CRC32=0x45c9381b,Flash_Header_CRC32=0xe1332d75
st_FlashHeader_Info.downloadtime=0xd5ef000
>> [USRDEBUG] DVB_DebugInitial success
========= Normal Play Init ========
CDAT >>
CDAT >>
****CT***** A1108_IABSRx_GetLockStat
****CT***** A1108_IABSRx_GetLockStatus FAIL********!
****CT***** A1108_IABSRx_GetLockStatus 超级终端连接 还有其他串口连接出错的信息 帮忙分析下
