  • 7352阅读
0-30V 0-5A可调电源TL431基准电压版 [复制链接]
bedz
级别: Mod
楼主    bedz 发表于: 2017-01-04 07:58:29
[backcolor=#ffffff][color=#333333][font=Arial]维修和DIY的必备家当 适合DIY自制(为了适合热转印采用[/font][/color][/backcolor][backcolor=#ffffff][color=#333333][font=Arial]单面板布线[/font][/color][/backcolor][backcolor=#ffffff][color=#333333][font=Arial])稍微改变一下阻容参数即可改成 0-60V 0-10A[/font][/color][/backcolor]
[backcolor=#ffffff][color=#ff0000][font=Arial]0-30V 0-5A可调直流稳压电源 [/font][/color][/backcolor][backcolor=#ffffff][color=#ff0000][font=Arial]注意:[/font][/color][/backcolor][backcolor=#ffffff][color=#ff0000][font=Arial]采用TL431电压基准 + C5200大功率三级管 (处理好散热[/font][/color][/backcolor][backcolor=#ffffff][color=#ff0000][font=Arial])[/font][/color][/backcolor][backcolor=#ffffff][color=#ff0000][font=Arial]          R10 R11 5W0.25R[/font][/color][/backcolor][backcolor=#ffffff][color=#ff0000][font=Arial]欧电流取样  C1 C2大电容选63v2200 -10000uf均可 U1 7812 U2 7912 [/font][/color][/backcolor][backcolor=#ffffff][color=#ff0000][font=Arial] 稳压[/font][/color][/backcolor][backcolor=#ffffff][color=#ff0000][font=Arial]          IV 4.7K电位器 (电流调节)PV 47K[/font][/color][/backcolor][backcolor=#ffffff][color=#ff0000][font=Arial]电位器(电压调节)IC LM358如需要可换TL082等芯片提高稳定精度[/font][/color][/backcolor][backcolor=#ffffff][color=#ff0000][font=Arial]          变压器 次级12v 24v经一两档开关输入到8A整流桥堆再连接到 C1C2 [/font][/color][/backcolor]
[backcolor=#ffffff][color=#ff0000][font=Arial]U3 431最好采用WS431 或TL431(手机、电动车充电器中大把拆)C5200 可用C5144 J6920代换其它无特殊要求![/font][/color][/backcolor]
