  • 2962阅读
其乐达ct216连接出现的问题 [复制链接]
楼主    dachun201 发表于: 2010-03-21 13:20:50
连完了之后出现了下面的东东,看不明白 请高手指点
boot v2.00
Flash Size:0x100000
tsloader_main:Apr 22 2009,14:12:52
...Press keyboard key=0xf time=0
Boot APP from Flash app type=1
Start App Dram ......
### io config initial ########
CT_OS_CreateHISR doesn't need a stack
HW_IR_NEC
DEV_KD_Initial Ok
System Heap Size = 2008616
lnb power overload irq enable failed!
Error::A1108_IBSP_I2CWrite HW CT_IIC_WriteData failed:EN_DRV_RESULT=2
u8Deviceid=0x18,data(size=0x7):60 00 00 00 00 00 00
AVL Chip:2-1-1
AVL Api:3-2-2
AVL Patch:4-1-32
>> Read NVRAM Success
>> MenuBmp_LoadPalette() : True
System Time Created
SysTimeSemaphore Created
ch_sw task Created
>>ap_ch_switch_lastgood
*** Unsupport OTA update! ***
>> [USRDEBUG] DVB_DebugInitial success
========= Normal Play Init ========
CDAT >>
CDAT >>
>> NIM : EN_NIM_TASK_STATE_SET_CHANNEL
u32Freq=1130000 u16SymbRate=28800 invert=0
AVL1108_RDA5812_Set_Tuner:slaveADDR=0x0c
A1108_IABSRx_GetLockStatus failed!ERRCODE=8
u32Freq=1210000 u16SymbRate=28800 invert=0
