  • 4506阅读
双口RAM的VHDL testbench [复制链接]
qgpltls
楼主    qgpltls 发表于: 2008-12-07 12:36:01
需要的朋友可以参考,我是用Modelsim仿真的
-- Designer : skycanny
-- Date   : 2007-2-3
-- Description : This VHDL file is a testbench file designed to simulate a dual port ram
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
entity dualram_tb is
end entity;
architecture Behavioral of dualram_tb is
constant delay : time := 3 ns;
constant width : positive := 16;
constant depth : positive := 8;
signal clka : std_logic;
signal wr : std_logic;
signal addra : std_logic_vector(7 downto 0) := "00000000";
signal datain : std_logic_vector(15 downto 0) := x"0002";
signal clkb : std_logic;
signal rd : std_logic;
signal addrb : std_logic_vector(7 downto 0) := "00000000";
signal dataout : std_logic_vector(15 downto 0);
component dualram
-- generic
-- width : positive := 16;
-- depth : positive := 8
port
------------------------- port a is only for writing -------------------------------
clka : in std_logic;
wr : in std_logic;
addra : in std_logic_vector(depth - 1 downto 0);
datain : in std_logic_vector(width - 1 downto 0);
------------------------- port b is only for reading -------------------------------
clkb : in std_logic;
rd : in std_logic;
addrb : in std_logic_vector(depth - 1 downto 0);
dataout : out std_logic_vector(width - 1 downto 0)
end component;
begin
tb : dualram
-- generic map
-- width,
-- depth
port map
clka => clka,
wr => wr,
addra => addra,
datain => datain,
clkb => clkb,
rd => rd,
addrb => addrb,
dataout => dataout
process
begin
clka <= '0';
wait for 13 ns;
loop
  clka <= not clka;
  wait for 10 ns;
end loop;
end process;
process
begin
clkb <= '0';
wait for 12 ns;
loop
  clkb <= not clkb;
  wait for 7 ns;
end loop;
end process;
process
begin
wr <= '1';
rd <= '1';
wait for 24 ns;
wr <= '0';
wait for 60 ns;
rd <= '0';
wait for 300 ns;
wr <= '1';
wait;
end process;
process(clka)
begin
if clka'event and clka = '1' then
  if wr = '0' then
  addra <= addra + 1 after delay;
  end if;
  datain<= datain + 1 after delay;
end if;
end process;
process(clkb)
begin
if clkb'event and clkb = '1' then
  if rd = '0' then
  addrb <= addrb + 1 after delay;
  end if;
end if;
end process;
end Behavioral;
