  • 7638阅读
PADS中字体属性的修改 [复制链接]
yuandm
楼主    yuandm 发表于: 2009-02-04 15:18:18
[post] 单击鼠标右键,选select components, 再单击右键,选 select all (CTRL+A)。再单击右键,选query/modify (CTRL+Q), part outline width 输入想要的宽度,下面选label, 选Ref. Des. Press the big button under it. 弹出新窗口, input the value you want at size and width. Press OK. Then the size, width , even the part outline width are same.[/post]
