  • 6276阅读
用编程器些芯片,只能读不能写,擦除和写入报错!请高手赐教是什么原因! [复制链接]
cjlyr
楼主    cjlyr 发表于: 2010-07-02 17:01:10
新购编程器读取备份正常工作,可是编程写入老是报错!
读取文件地址 N:\中9\0623\YANWEN~1.BIN
0x100000 bytes
准备擦除芯片
Status REG = 0xFF
Disable sector protect..
准备擦除16 扇区
.擦除 扇区. 1 地址为. = 0000
Error erase block 1 with addr = 0000
.擦除 扇区. 2 地址为. = 10000
Error erase block 2 with addr = 10000
.擦除 扇区. 3 地址为. = 20000
Error erase block 3 with addr = 20000
.擦除 扇区. 4 地址为. = 30000
Error erase block 4 with addr = 30000
.擦除 扇区. 5 地址为. = 40000
Error erase block 5 with addr = 40000
.擦除 扇区. 6 地址为. = 50000
Error erase block 6 with addr = 50000
.擦除 扇区. 7 地址为. = 60000
Error erase block 7 with addr = 60000
.擦除 扇区. 8 地址为. = 70000
Error erase block 8 with addr = 70000
.擦除 扇区. 9 地址为. = 80000
Error erase block 9 with addr = 80000
.擦除 扇区. 10 地址为. = 90000
Error erase block 10 with addr = 90000
.擦除 扇区. 11 地址为. = A0000
Error erase block 11 with addr = A0000
.擦除 扇区. 12 地址为. = B0000
Error erase block 12 with addr = B0000
.擦除 扇区. 13 地址为. = C0000
Error erase block 13 with addr = C0000
.擦除 扇区. 14 地址为. = D0000
Error erase block 14 with addr = D0000
.擦除 扇区. 15 地址为. = E0000
Error erase block 15 with addr = E0000
.擦除 扇区. 16 地址为. = F0000
Error erase block 16 with addr = F0000
16:53:51
正在编程请等待:...Error完成
16:53:59
不知什么原因!
芯片:
