  • 3425阅读
哪位有MSt717C数据手册 [复制链接]
nhdcd
楼主    nhdcd 发表于: 2010-11-23 10:44:15
下了717量产代码和手册,发现手册上bank1里C1h到CFh是说保留,但实际代码里是有定义的,可能是手册太旧的缘故。
#define    BK1_C1_BND_RST            0xC1            // Bonding reset
#define    BK1_C2_LMT_ADD_NMB        0xC2            // Limit adjust number in acc_fpll mode
#define    BK1_C3_IVS_DIFF_THR        0xC3            // Input VS different threshold
#define    BK1_C4_IVS_STALBE_THR        0xC4            // Input VS stable threshold
#define    BK1_C5_CH_CH_MODE        0xC5
#define    BK1_C7_IVS_PRD_NUM_L        0xC7            // [7:0]:Count number per input VS low byte
#define    BK1_C8_IVS_PRD_NUM_H        0xC8            // [3:0]:Count number per input VS high 4bits
#define    BK1_CB_IPOL_SET1             0xCB             //POL_PVI_10IN 3 POL Output to SEQ_MOD Pin if EFh[7] = 0. 20060413
// TCON signal control
#define BK1_CD_GPO_OEV2_WIDTH    0xCD
#define BK1_CE_GPO_OEV3_WIDTH        0xCE
#define BK1_CF_GPO_OEV_DELTA        0xCF
